I2S Chip replacement
I hope I have posted in the right area.
I bought a dac hat for my RPi4. I fed it 24V when it was on the Pi, causing a bit of smoke.
I replaced the Pi, put the hat back on, but it is not working.
I am planning to change each component, and see whether I can resurrect it.
The one chip that has no id is the chip marked as the I2S chip.
I am wondering if anyone has any idea of what this chip is? it measures 4x4mm.
Thank you in advance.
If there is a voltage regulator between the 5 V input and the rest, you might have only fried the regulator. If not, it's probably hopeless.
Many years ago I built a circuit for an aunt of mine that was supposed to be supplied from a wall wart. At some moment, due to miscommunication, she had the wall wart replaced with a mains plug. The only parts that needed to be replaced were some diodes, an electrolytic capacitor and a voltage regulator, everything behind the regulator survived.
They are both programmable logic.
CPLD = Complex Programmable Logic Device
FPGA = Field Programmable Gate Array
so while I could link you an example of both, but it would ultimately be of no use to you, as it is the 'program' in programmable, you will be left wanting. the idea is, it is programmable logic hardware, used to leverage hardware speeds against a software task and you dont have the software.
If it is a CPLD or FPGA, it is an exotic part, because if you check all Xilinx, Altera and Lattice portfolio, you will not find a QFN28 packed one.
Edit: I forgot to mention Microchip - same situation - no QFN28 packed CPLD or FPGA chip.
Good call, maybe something simpler - pic32mx1xx series. Comes with i2s interface. Still needs programming.
Check the wiring on the circuit board, such as the QFN32 package version of CT7302. I am also using this chip.
https://www.comtrue-inc.com/index.php/download2?task=download.send&id=20&catid=5&m=0
