Unknown English power amp
Hello.
Does anybody here know anything about this old amp?
Manufactured by harmonic communications Uk
There is no type number on it.
Still in business but its a telecommunications supplier mainly, I doubt if you will find a schematic it sells to the trade , nothing is impossible it could be converted but you will need to do some "reverse engineering " unless somebody here knows more about it.
My search also turned up with telecommunication, and my initial thought was it was diy, but the back plate looks factory made, the seller promised a inside picture, maybe it will tell more, looks like only two to3 pr channel, well have a nag for odd stuff, could be fun.
Take the covers off the power transistors, see the markings...some companies used to sand them off.
TO-3, so most likely 3055/2955, BDW series or MJ series. So mostly a fairly common circuit then, and still used for rugged amps.
Individual volume controls.
Such an industrial looking thing.
Check it out on power with a bulb in series, after a thorough inspection, if it passes that connect to speakers...
A 3 pin DIN the UK usually has a first choice of being a microphone input --yes looking through my books on microphones many UK types used DIN others used jack -plugs/sockets .
I hope you are right and I am wrong as to its use .
The second pic (its a bit dim to see clearly) shows phone jacks plus standard 3 pin XLR panel sockets and plugs for balanced input and output connections respectively, as you'd expect with a stereo, utility PA amplifier. It won't be a Hifi amplifier but no doubt could be used in the home if the noise and distortion levels were going to be acceptable.
Just recived theese pics.
I havent even had a look at them yet, here they are, its definitely a audio amplifier, pretty nice interior.
