Building a simple source selector
Hi Guys,
I am sure not to be the only one who doesn't have enough inputs on his amplifier. For my "office" setup I am using a Pioneer SA-508 that I have restored. But with tape, reel too reel, tuner, CD player and Mac I am short of at least one input.
Trying to get away with the most simple passive design a possible. Found a switch that has one "output" and five "inputs". Each got two connectors. So that works for Left and Right.
But and thats the big question, I need to hook ground up together for all devices. Is that doable? Do I sacrifice on audio quality? Or is ground just ground and it doesn't matter?
A long time ago I had the same need. As I have reel to reel recorders, I also wanted to be able to route inputs signal to tape outputs, and also copy from a recorder to the other one.
I had some perfectly adequate ELMA rotating switches lying in a drawer and a bunch of RCA sockets, so I ended building this : Sélecteur de sources - Google Photos
Soundwise, quality switches and good soldering job make it completely transparent.
Case is from HiFi2000, faceplate engraved by Schaeffer AG. Neat little project.
Here is my solution. Input grounds of L are on a bus, same for R on a separate bus. Output grounds come from the active circuit, also separate L and R GND. Phono GND is also separate. Hangerőszabályzóhoz = to volume control.
