Revolution Cabinet Plan
Thanks! Yeah, saw that, which with a picture to scale off of is good enough for a decent DIYer and presumably the local cabinet maker, but he wants blueprints, so the plans are probably [a lot] cheaper than having the shop do it.
Front Baffle Diffraction Treatment
For the front baffle, which one is better between a 45 degree chamfer, a 1/2" roundover or a slanted chamfer like the picture below?
The oval PR from SBA has only small linear excursion , too stiff a suspension!
And the straight plane segments of the paper cone are easy to vibrate , add a damping pad there on both segments ...
This PR is only suited for low playback volume and not so low tuning frequency!
