Just a quick question, I want to assemble a five channel power amp using five mono mosfet amplifiers, each has a voltage range 15 to 70v, 150 watts in to 8 ohms. I am also using 3 dual rectifier boards 100v 120a. My question is can I parallel 3 transformers to power each rectifier board or use one transformer and connect the rectifier boards from dc out to ac in
First large project, might be too large.
Nobody has heard of a condenser microphone?
RE: OP question. Kemet make excellent parts. So does TDK/EPCOS like this one: B41505A7109M000
Yup, replacing "points, plugs, condenser and cap" did it many times growing up, it was called a "tune up". Then pull out the strobe, hook it to spark plug number one, turn and lock the distributer until you reach "top dead center" on the flywheel!
My pappa got sick of that and ripped it out and put in a 'transistorized' ignition!
- Power Supplies
- Condensers in power supply
