Dear all,
Hope everyone is doing great!
I am facing this issue when trying to program 3e Audio's SY-DAP2002 DSP. I have connected the USBi connector to the amplifier board and in Sigma Studio Hardware Configuration page, I can see that USB is connected (green box).
The problem comes about when I press "Link Compile Download" button and the following error appears as in the attachment. Trying to change anything in the User EQ section also does nothing to the sound.
I have tried both SigmaStudio 4.5 and 4.6 and both have the same errors. Has anyone met this problem before and have a solution to it?
Thank you!
Thank you!
Do you get the same error if you just do the "Link" command? That would indicate an error in the schematic. If you zip up the project and post it we could take a look at it.
Please try 4ohm version.
The 4ohm version is perfect!
@ernperkins Yes the same error is there. I used the 8ohm sample files from 3e Audio without any modification. the 4ohm version of the files are perfect!
Don't ask me how but some of my SigmaStudio projects seems to go corrupt for no reason at all. I just recreate any project from scratch if SigmaStudio starts to act cranky.
