I am pretty new to working on things and was unable to find a thread with good recommendations, i think the issue is .. i have no idea even what the proper nomenclature for the part i am looking for would be.
I have seen a variety of old receivers come and go through my hands and a common problem is old switches that have been sheared off or other ..
Currently i have an old Nikko NR-1015 with a broken shaft on the speaker selection switch the settings are Off, A, B and A+B it appears the positive amplifier runs to this and is passed accordingly while the negative appears to run right to the terminals. similar to a home light switch)
I am looking for a suitable replacement but there are a lot of terms with regard to polls and such i am not sure what the right description for this switch would be for a company like C&K switch' or others to even know what to search for 🙁
thank you guys .. I think I understand 2 pole 3 throw means off (throw 1 with no pole) throw 2 = Pol1 throw 3 = Pole 2, doing the A+B would basically pass back to the first 2 pols with a jumper/ ?
For me personally id be fine with off and speakers A, but to get things back to proper operating condition id want to find a substitute or a hand full to put things i find back in service
You could use a simple single pole, 4 way switch, two relays and some diodes to do what you want, but you would need a supply for the relays. Probably easier than finding a replacement switch though
Brian
Brian
The Dynaco PAT-5 preamp had a rotary switch that did exactly the same thing.
Maybe you could find one on ebay.
Dynaco PAT-5 Stereo Preamplifier Manual | HiFi Engine
Doesn't work. Try sketching it on paper and You'll find it is impossible with and ordinary switch.
My Pioneer SA-606 has the same function.
The Wiper contacts are custom made.
Perhaps You could do it with a 3 or 4 gang switch and using the 3rd & 4th gang for shorting A & B on the 4th position.
There are some Nikko speaker rotary switches on ebay, the problem is they're speaker off > a > a+b > b
NIKKO STA-5050 RECEIVER SPEAKERS POT | eBay
NIKKO SPEAKER POT 4 POSITIONS 2025 STEREO RECEIVER | eBay
Speakers rotary wafer switch for Nikko STA-8080 P/N 405039 O SR26N 1-2-4 | eBay
And this one is five position, power off > a > b > speaker off > a+b
Nikko 6065 Original ON/OFF/Speaker Selector Switch. Tested. Parting Out 6065 | eBay
1/4" is 6.35mm, not 6.33mm
"1/4 inch" often really means 0.249" to ensure a 0.250 inch knob will fit.
There's also a LOT of metric stuff which is just plain 6mm.
- Design & Build
- Parts
- 1/4" (6.33mm) split Speaker Off, A, B A+B
