Catridge with "prettiest" square wave response you've seen?
Hi, what's the "prettiest" square wave response you've seen from a cartridge? Thanks all.
attachment.php
This is a theoretical question, because:
  • Music does not contain square waves
    It is impossible to cut square wave with infinite rise and fall time on vinyl
    Most of us do not have any test record with "square wave" signal
    Audio magazines or labs could not test all cartridges ever existed
    No louspeaker or headphone, even electrostats can reproduce a square wave perfectly
That said, for reproducing a steep rise signal with minimal ringing, one needs a very low mass cantilever/stylus/moving part (magnet or coil) cartridge, with short and rigid cantilever. Here is one legendary example:
The Dynavector Karat 17D2 MK.II MC Cartridge by Vangelis Lazarou
Here is a Stanton 881s with 2 different capacitive loadings. The top trace is 330pf and the bottom is 50pf. I can't find the trace I did with the correct 275pf loading.
LP is the CBS ST100 directly out of the cartridge
See below
Response to a 1-kHz square wave from CBS STR-112.
The output impedance is a pure resistance of 5.15 kilohms, and the square-wave response was unaffected until a total capacitance of 1,000 pF was placed across the output terminals. Changing the resistive load on the cartridge from the standard 47 kilohms affected only the output amplitude and not the wave shape (as observed on a 'scope). Figure 3 shows the response to a 1-kHz square wave using the CBS STR-112 test record. The rise-time was found to be 13µS
Many/most/all(?) squarewaves on test records aren't riaa eq'ed, so going through a pre will distort the signal.
Carts a Miro Acoustics 630 eletret with inverse riaa built in so don't know if they somehow bypasses that or not?
