LuFo Amp - 39w SE Class A from 28v Rail
Founder of XSA-Labs
Joined 2012
Update Nov. 2, 2021 - Final manufacturing files with Vds bias voltage mod for LU1014D as suggested by Mbrennwa. Files are located here. A huge thank you to JPS64 for making the mods to the layout.
Update Oct 19, 2021 - Final manufacturing files (Gerbers, BOM, schematics) can be found here. A big thank you to JPS64 for making the beautiful layout.
In the course of testing the new aluminum IMS PCB adapter board for the LU1014D group buy by member Wg45 (with LU1014D's provided by Mr Pass, and the testing is being performed by Woofertester), I realized that the LU1014D can carry a lot of current and can now be cooled easily and effectively. The ability to mount and cool it easily, combined with the use of a MOSFET cascode stage to increase the rather low 20v limit gave this little transistor new life as an audio output stage. Inspired by Michael Rothacher's (and his alter ego, the “Dude”)excellent MoFo amp, which I built several years ago when it first came out, I saw that something simple and similar could be done here. I wanted to make something that folks could easily make using scraps from their bench without resorting to a high dissipation MOSFET like an IXYS, or fancy CPU coolers and fans. No, just conventional IRFP240's can be used and at safe levels of dissipation of only 25w each - suitable for mounting on a passive radiatior heatsink like a 4U x 300mm one from Modushop.
Here is the resulting schematic from LTSpice doodling. It has a minimal parts count, yet the performance is quite nice. With a 28v supply and about 3 amps of bias current, the simulations predict that it can get up to 39w into 8ohms before clip sets in. The THD at full power is a little over 0.13% but only 0.01% at 1w into 8ohms and 0.03% at 8w into 8ohms. Of course, all this is with a nice SE Class A harmonic profile that is dominant second order and monotonically descending higher orders.
Here is the schematic:
954037d1621739943-lufo-amp-39w-se-class-28v-rail-lufo-triple-irfp240-v1-png
Here is the predicted FFT for 1w into 8ohms (8vpp) - it gets 0.01%THD and a beautiful harmonic profile:
954038d1621739941-lufo-amp-39w-se-class-28v-rail-lufo-predicted-fft-8vpp-8ohms-png
At an average and rather loud level of 8w into 8ohms - it gets about 0.03% THD and still maintains a nice harmonic profile:
954039d1621739943-lufo-amp-39w-se-class-28v-rail-lufo-predicted-fft-22-6vpp-8ohms-png
For the purposes of a proof of concept build, I am using CPU coolers and a Noctua fan since I have a pile of them and only 1 conventional 4U x 300mm chassis from Modushop, currently occupied by an Alpha Nirvana (which, btw, has the same output power and dual rails). But the PCB that JPS64 will be doing the layout for me will be a large conventional design with widely spaced MOSFETs (probably UMS compatible). Here is how I am stacking the three MOSFETs (some NOS Phillips PSMN020 150w's that Hugh Dean gave me a while ago) on the Dell CPU cooler, to which I will directly solder a veroboard and build the amp on:
954040d1621739943-lufo-amp-39w-se-class-28v-rail-lufo-build-01-jpg
Here is how the LU1014D is mounted onto an IMS PCB adapter that lets it be used like a TO-247:
953093d1621440649-lovoltech-lu1014-power-jfet-buy-lu1014d-to247-adapter-heatsink-02-jpg
Here is a closeup of the completed amp - all of it fits on the little veroboard - except the LU1014D and the 67mH (0.5ohm DCR) microwave oven transformer (you can get surplus (MD 803AMR model) ones similar to this one on eBay), which are attached with 18ga silicone wire flying leads and pin end crimped tips for the screw terminal blocks:
954041d1621739943-lufo-amp-39w-se-class-28v-rail-lufo-build-02-jpg
I am using an active bridge (LT4320) rectifier, with a CRC, and a BJT cap multiplier single rail PSU (I measured ripple under 3A load at less than 1mv rms). Although, I think this amp has decent PSRR due to the cascode feedback - so a conventional CRC might just work swell without audible hum:
954043d1621739943-lufo-amp-39w-se-class-28v-rail-lufo-build-05-jpg
Here is the first power on test, the amp reached 3A bias current, the voltage at the LU1014D source pin was around 1.5v, and the voltage at the LU1014D drain pin was around 4.2v - pretty much spot on from the simulations. No magic smoke was emitted, and everything was stable. I adjusted the trimpot slightly to achieve about a 3v difference between the drain and source pin of the LU1014D:
954044d1621739943-lufo-amp-39w-se-class-28v-rail-lufo-build-06-jpg
I then connected the Pass ACP+ as the preamp - knowing that this will not achieve the full power since it does not have the ability to put out 50Vpp swing - but it will let me test the sound a reasonable volume:
954042d1621739943-lufo-amp-39w-se-class-28v-rail-lufo-build-04-jpg
Here it is playing music - it sounds great! I also tried it with a Melbourne preamp that can swing 55Vpp and it does indeed play loud. The bass impact is particularly good for a SE Class A amp. The combination of the low Rdson of the LU1014D and the reactive load of the 67mH microwave oven transformer (MOT) combine to give this amp a predicted damping factor of 157 at 50Hz:
954045d1621739943-lufo-amp-39w-se-class-28v-rail-lufo-build-07-jpg
This amp sounds very nice - smooth and similar to the MoFo, but with a different - more muscular feel, perhaps a bit less distortion. It certainly is easy to build and if you already have a MoFo, you are 80% there. It works fine at 20v or 24v too - just lower output power.
It is a simple and easy amp to build - you will need either a Hammond 193V inductor or pull one from an old microwave oven (or buy those on eBay for about $25) and a powerful preamp if you want to reach the full 39w potential.
We now wait for JPS64 to design us one of his masterpiece PCBs - this should be really cool.
Edit May 26, 2021: max power before onset of clipping is 17.77vrms into 8ohms. That’s 39.5w.
955036d1622062551-lufo-amp-39w-se-class-28v-rail-df15f3c7-978b-4edd-b7e8-d3d1367aba0d-jpeg
Edit May 24, 2021: Measurements for 1kHz 2.83vrms into 10ohms
954528d1621898005-lufo-amp-39w-se-class-28v-rail-lufo-2-83vrms-10ohms-fft-jpg
8Vrms into 10ohms:
954530d1621898005-lufo-amp-39w-se-class-28v-rail-lufo-8-0vrms-10ohms-fft-jpg
Mouser shopping cart here (thanks to Vunce):
Prototype LuFo UMS compatible production board built by Vunce:
961586d1624332091-bench-tonight-obt-7a850f46-9d48-493b-8521-32a5d2da0194-jpeg
June 25, 2021 - Vunce’s verification build in stereo:
962669d1624677595-lufo-amp-39w-se-class-28v-rail-13edfc1a-733e-41ba-bb0c-875b701dbc37-jpeg
June 28, 2021 - Note that use of non-audio specific chokes like MOTs or Hammond power supply filter chokes may not provide optimal performance when playing sustained bass heavy tracks - this will deplete the magnetic energy stored in the choke and may cause intermittent clipping of high crescendos when preceded by deep bass lines. More info here:
Edit July 10, 2021: LuFo Lite - a 5.6W 12vdc supply LuFo without a cascode:
966134d1625949084-lufo-amp-39w-se-class-28v-rail-lufo-lite-schematic-v1-jpg
Thanks, guys!
@koja: no measurements yet. I will listen for a few days first to make up my mind subjectively. Usually, the shapes of the harmonic profiles are accurate for SE Class A amps, if the model of the actives are good. Distortion doubles for 4ohms unless bias current is increased.
On the lunatic fringe, love the experimentation! UMS compatibility will be nice! I have a UMS 5U heatsink waiting for further experimental designs. Looking forward to future posts...
For the choke, perhaps the Lundahl LL2733 with coils wired in parallel?
http://www.lundahl.se/wp-content/uploads/datasheets/2733.pdf
Inductance is then about 0.1 Henries, DCR is about 0.85 ohms, operating current is 3.4A and saturating current is 5.4A.
Best,
Anand.
Best,
Anand.
LL2733 is too small; it is rated 60 VRMS at 100 Hz.
At 20 Hz it will handle 12 VRMS (18 watt 8 ohm).
For a quality choke there must be ample headroom, otherwise you throw the child away with the bathwater 🙄
Daanve,
Thanks for clarifying that oversight on my part!
Let's throw a list together of commercial chokes that can be used (not MOT's) in case some of us would like to $$$. The choke is a very important part of this circuit imho given how simple of a circuit it is.
Hammond 193V
Looking through the Lundahl catalog, I don't see anything that fits. Might need to do a custom order through Toroidy 😛
If X or Daanve, can give me a list of design specifics (to especially maximize the performance of this circuit), I'll enquire with Toroidy about cost, etc...
Best,
Anand.
LU1014D is a very high transconductance device, so output impedance of the amp will about equally the choke DC resistance.
It depends also on the loudspeaker, but IME damping factor should be not much less than 20 before bass looses control.
That asks for max 0,4 ohm DCR for the choke.
Hi Anand,
The choke I used was something serendipitous. I have tested it before on a 50w into 8ohms MoFo like amp designed by Hugh. MOTs appear ideal as they have the low 0.5DCR spec, have an air gap to prevent saturation, and as I recall, were rated 10A DC current.
They also have a secondary that makes kV. So be careful. Could be useful for driving electrostatics from this amp?
The 193V is closest I see in reasonably priced commercial.
If ordering custom trafo, ask for 5A min, 0.5ohm DCR max, 68mH min, silicon steel plate laminate. I have asked a custom manufacturer in USA and got a price in $350 range.
There might be a custom house in China (where MOTs are made) that can do a large order fir a lot less. GB time?
