A good schematic for a pentode wired El84 SE amplifier
I'll post what someone else said about it after I posted the one I made for a friend. Screenshot_2021-05-22-21-19-45-03.jpgScreenshot_2021-05-22-21-20-01-56.jpg
How exactly small your small power transformer is?
You'll need something like 160-180mA rated secondary at least with the SS rectifier.
Il not sure, but It was used orginally in a radio console amp. And was powering 10 tubes . I have not calculated the draw in total. But it runned orginally with 1 x 12ax7 and 1x el84 each channel.
Been a long day and its almost midnight here and im tired so i gave them a totally wrong name lol. . pull down resistors is something totally different.
The resistors between the power transformer and the tubes, that lowers the voltage going in to the the tubes i was thinking on.
After some google i found out that the The max voltage for El84 tubes are 250v ?
and the b+ in the chematics on the RH84 was 315v . And i have 275-280v out from my transformer. After rectification.
So i was thinking i maybe have to change the values on the resistors so that i don't get to low voltage. On the tubes.
Historically EL84 despite their ratings were often run at plate voltages in excess of 400V particularly here in the U.S. The Russian 6P14P will survive this without issues, and is a good example of/replacement for a 7189 type.
If 300V and below I've found the JJ EL84 to be a good sounding choice.
In NOS all the usual suspects are good; RCA, GE, Telefunken, Mullard, Amperex, Philips (particularly the E84L)
Build as designed, test, and then adjust voltages only if required. There is pretty significant latitude as long as you are not over the tube's safe plate and screen dissipation limits. I imagine it will be just fine - it is a well proven design.
I have a good quartet of telefunkens - not NOS but low hours and test as new. I keep telling myself I need to build a small SE amplifier to use them.. My first stereo tube amp as a teen was a salvaged Magnavox with a pair of EL84, E83CC, and an EZ81 - it sounded pretty good. I've been doing a lot of solid state and hybrid stuff so no idea when I will get to it.
