6N3/6N6 headphone amp using PCB.
When I am running your diagram in LTspice and doing an analysis I get DC voltage at the common point cathode top tube and plate bottom tube of the 6N6 triodes around 59.5V which I find low. Isn't it better to get there around halve the supply voltage. (=280V)?
But perhaps I do not have the correct 6N6 models.
IF you change R1 from 82R to 100R that will reduce the current. The tubes don't need matching for WCF. I would be surprised if the ECC99 and 6N6P should different with the linearity of the circuit - tubes don't really have a sound.
I use 182 ohm for R1 now. Well sommething changes when I change the tubes. (sound)
Well I am now a little bit puzzled here about the actual resistor values 182 Ohm, 82 Ohm 100 Ohm?
Is it possible to post the actual resistor values of all resistors which are now "in the hardware"?
And perhaps someone can shed some light here about that global feedback. It is connected from the output to the grid at the input tube, which has a series resistor of 100k.
Then in the simulation there is that voltage source, but in practice it will be an input volume control resistor.
Isn't then the amount of global feedback depending on that volume control actual resistor value to earth?
I am using this schema except the cathode resistor 182 ohm.And Ecc99.... And then 6N2P as input tube
And I use a 1ooK potentiometer.
945410d1619197261-6n3-6n6-headphone-amp-using-pcb-screenshot-12-png
When I am running a DC analysis my DC values differ from yours significantly.
For instance the plate voltage of U3 = 83 V in my analysis and around 122V in yours. Same for the output voltage:
mine: 89V, yours: 124V.
I am using 5751 and 6N6P both Ayumi Nakabayashi models.
plate current U3=1.64mA and plate current U1=17.7 mA.
both in my LTspice circuit.
Circuit components are now the same as yours.
I would stick to 82 - 100R as it sets the current in the output and hence what you can drive. If you make R1 182 you should also make the final plate WCF resistor higher too. Yes the input pot will have some effect on the feedback that's why the input resistor is big.
