It'll be fine.
If you ever want more bass you can easily add some subs.
Not sure about the roll back on the baffles. It would probably be better but I don't know(or have the patience) on how to simulate it.
Use ARTA or any other real time analyzers with a mic on a boom or mic stand to see how the response changes with angles as you move across the listening plane. Physically move the mic while simultaneously looking at the screen. Saves a lot of time.
Only correct the issues that track at angles. Other peaks and dips should be addressed mechanically or ignored.
It'll be fine.
Okay, thats what i thought. Thank you!
What i extracted from briefly reading over this is that its mostly about reducing floorprint of the speaker and some distortion reduction. Though i have never seen a comparison of one slot loaded driver vs the same driver in the same slotless baffle. The distortion reduction could come from the added drivers on the same space i guess. Since the BMS driver has alright distortion i probably wont bother with this and the linkwitz transform can take care of qts and fs so the only actual benefit would be looks. I will think about it
You'll probably have a huge room mode peak low down that you'll have to cut. 😉
i use rew with apoeq and plan to get room treatment in place as soon as i can start using that room for audio!
I am not saying that it won't work.
Here is the summary of what I say:
With one 15" per side (reasonable u frame), you will get usable bass down to 50hz. With two probably 40hz.
And it will be prudent to apply a high pass filter at those F levels unless you listen low bass/low volume.
OB bass down to 50hz is still awesome...
What i extracted from briefly reading over this is that its mostly about reducing floorprint of the speaker and some distortion reduction.... I will think about it
You won't reduce floorprint with this config (or a simple SL a la N.Pass) as the cavity usually add ups volume.
Distortion reduction ( 2nd harmonic) is the whole point of this config yes ( as are push pull in general).
You could find some comparison performed: search for the one performed by Weltersys with a pair of Eminence 12" lab subs, it include measurements,etc,etc,... Typical from someone serious about his design and evaluation.
You'll see that for him it is not to his taste: the fact there is cancellation of 2nd harmonics doesn't cope with his preference when you push the level ( the ratio between 2nd and 3rd harmonics is modified making the third more dominant hence a different rendering).
If you ever heard a servo sub ( distortion reduction through feedback from cone motion /active system) results are not very differents, in the same kind of family.
Food for thoughts yes, that is the point. 😉
I am now leaning towards a modified ripol design or the early linkwitz slot loaded subwoofer without double drivers. This would my problem of designing a good looking baffle due to the way smaller footprint. The nelson pass variant is interesting but in its original form not really my thing. I will experiment with said designs and removed tops, unequal sides, etc
- 10" mid in WMTM baffleless speaker
