Rod Coleman:
The Sovtek, EH and Gold Lions are all made in the same factory: Reflektor, Saratov.
I don't believe any suggestion that a different line is used to produce them.
They do look exactly alike. I have all of them. IMHO, the JJ's are clearly better sonically. Tied with the EML in my system.
Not a different production line, but different selection grades.Rod Coleman:
Thats what has been always done for grading tubes, strong selection of the best production pieces.
If someone wants to buy bad tubes, buy cheap tubes.
Because valves change over time. EML 300B keeps up a prolonged uniform listening experience compared to less expensive products. It is your choice to buy three pairs of cheaper tubes instead.I agree but if they don't sound better and cost 3 times as much then why spend the extra money?
Do not misunderstand me, I am happy with my JJ EL34-II quad (€68) and do not want to invest in Sophia Electric (€600). Although reproduction is bettered the price difference is simply too steep for me.
I have a brand new pair of gold lions. There have been some speculation about filament failure (disconnection), but it seems this has been concluded because of failing EH 300b filaments and the similarity in construction.
Does someone know if this is a real problem with the gold lions or recent EH production?
Hello guys,
My Gold Lions died at this point after good year of use. It was filament failure...
Very disappointed🙁
Amp is Tubelab TseII, 380v plate, 60mA...
What now?
At that moment I don’t have the money for EMLs... I’m afraid to buy Russians once again...
Do you think that JJ are sonicall on same lavel as GL?
BR
Goran
I strongly suggest you forget Russian 300Bs. They are poor for reliability. Filament has always been their weakness, despite they say it has been fixed. Now and then it reappears....
JJ 300B or good Chinese replicas are miles better for this aspect and also perform very well, if used properly. Do not believe what people say about comparisons with the usual uncontrolled tube rolling....
My favourite Chinese 300B at the moment is the Billington Gold Special Edition. These are the best measuring 300Bs of their Chinese stock, carefully tested, selected (for both measurement and appearance/construction) and guaranteed 12 months. Wholesale price is 76 GBP per tube. They are sold in matched pairs.
To get the wholesale price you need place an order which amounts to 240 GBP.
If spend less it becomes much less convenient because you must add +50%....
They have a huge catalogue:
Billington Export: UK supplier of electronic tubes and valves
My favourite Chinese 300B at the moment is the Billington Gold Special Edition. These are the best measuring 300Bs of their Chinese stock, carefully tested, selected (for both measurement and appearance/construction) and guaranteed 12 months. Wholesale price is 76 GBP per tube. They are sold in matched pairs. To get the wholesale price you need place an order which amounts to 240 GBP. If spend less it becomes much less convenient because you must add +50%....
On the subject of Billingtons, I asked for confirmation of a price on a tube, which was listed as £10 and they quoted me £20. When I questioned it and pointed out the catalogue price they said they could "hold the price at £15 for me" adding the 50%. Make of that what you will.
I've never had a 300b fail on me, but I only use Rod Coleman regs, never AC, and I run them well below their potential at 2a3 operating points. I'd guess that the combination preserves them more than in some other systems.
Yeah, you need do read all their conditions and they update prices often...following trends. At least now prices include VAT...but for more common stuff prices do not change that much.
@Andy your pm box is full.....lol
Just unblocked my box....
"à la tête du client"....... as my girlfriend used to say when we were selling jewellery on the Cote d'Azur in the 70s.
Hello 45,
Thanks for the tip...I have also found this Billingtons in Watford Valves...
Do you have any idea about the sound signature? How they compare to EH, GL, JJ....?
BR,
Goran
I had a look through the Chinese budget 300b tubes, and whereas in the past there were several variants, it seems that the two currently being offered are these:
Shuguang 300b-98
PSVane 300b HiFi
Has anyone used either, or can compare them?
I read one review of the Shuguang 300b-98 which was positive:
"Half the price of others, better sounding, over all, than JJ or EH. This is the “benchmark” tube that got stuck with the 7.5 rating by default. But the cheapest tube in the roundup is good, I thoroughly enjoyed every moment listening with the 98. This is the tube you’ll see shipping with any number of China-made 300B amplifiers. Shuguang has several grades of the same tube, in any case, this is a warm, musical tube with plenty of detail and lots going for it. 7.5"
Shuguang 300b-98
PSVane 300b HiFi
Having looked online at number of varieties of budget 300bs, I see most of them have the same anode structure as the cheaper Shuguang and PSVane ones, long plates with 5 ribs and 4 holes just like the WE original.
The exception is the "mesh" or perforated plate 300b-N version from TJ and PSVane. This looks line the model to go for, according to reviewers who seem to like it quite a lot.
I bought quad EH 300B gold for $322 2 years ago to replace the 10 year old Shuguang 300b even thought it's still working. It's pretty decent compare to Shuguang 300b. Maybe will try Shuguang 300b-98 later since I heard a lot people 're using it.
Thanks. I have some EH. Could you compare the sound of that compared with the Shuguang?
It would be hard to compare because the Shuguang 300b was over 10 years old and it's not Shuguang 300B-98 either. There is nothing wrong with Shuguang 300b tubes except I like to get a new quad. It's amazing that the bias is pretty much the same when I check every year. The EH is very well balance between bass and treble and the clarity of vocal that I really like. There is a youtube guy that builds amp for his customers, he always use Shuguang 300B-98. I am going to listen to EH for 2 years then try Shuguang 300B-98. I also have my eyes on WE 300B but still think about it.
Right now the Shuguang Treasure 300B-Z tubes are on sale. Mesh plate with the black coating, they sound really nice IMHO.
I have both the Psvane HiFi 300B and EH 300B Gold. I can measure a slightly lower distortion with the EH, but can not hear the difference.
Do all the 300b-Z have mesh plates? Impossible to see in the photos because of the black glass. In addition there are a couple of different types calling themselves 300B-Z e.g.
Matched Pair LINLAI Z Series 300B-Z HIFI Audio Vacuum Tube Amplifier Classic New | eBay
1 Matched pair premium Shuguang Treasure 300B-Z Vacuum Tube Replace 300B WE300B | eBay
And is the "mesh" plate the usual perforated one, as in the 300b-N?
Matched Pair LINLAI N Series 300B-N HIFI Audio Vacuum Tube Amplifier Classic New | eBay
And is "Linlai Store" in any way connected to Linlai or is it a rebadged PSVane?
Golden Dragon.
I bought a matched pair of Golden Dragon 300Bs on ebay for €100. I use them all the time and like the sound. Nothing wrong with them, in my opinion.
- Tubes / Valves
- Budget 300b tubes recommendations
