Greetings to all!
I want to ask the advanced self-builders. What will happen if you install Purify 1ET400A modules in NAD M22, which has Hypex NC400 OEM modules. What do you think about this?
Pin of Hypex NC400 OEM in NAD M22
is same as pin of:
1) NC500 - Hypex Electronics B.V.
2) 1ET400A - 1ET400A - PURIFI
NAD M22 has a smps +/-64Volt.
Service manual for Nad M22 with shematic:
NAD M22 SERVICE MANUAL Pdf Download | ManualsLib
is same as pin of:
According to TomChr, the pinout between the modules isn’t exactly the same. See here: https://www.diyaudio.com/forums/vendor-s-bazaar/351387-purifi-1et400a-hypex-nc500-input-buffer.html#post6127351
Whether this is a problem or not, I don’t know.
pin 28,33,34 -NC-not connected in 1et400a, in NAD M22 pin 28 also - NC. Pin 33,34 are connected to bi-color led, which only indicate overload. I think it is no problem, if we will not see this lights.
The actually question is, what are the differences in sonic character between both Class-D power amp units ?Greetings to all!
