Good read: Audioholics‘ about science/religion
Aww, pshaw. Streaming audio causing environmental damage sounds like the Dilbert comic "I have no skills or other useful talent, so my job is "raising issues"...
What about video streaming then? When I worked at Intel, one of the big tasks for certain server platforms was transcoding. Because Apple devices dont use the same file format as everything else, this giant 100's of watt CPU has to crank through the whole thing, replacing this byte for that one, in order to serve it out in a format the Apple device can understand.
I wonder how much global power that "just because Steve said so" burns? Perhaps it's not an issue anymore...
Then there's this ridiculous crypto currency crap, where huge numbers of top performing silicon are cranking through algorithms in the "hope" of finding instances of just the right sequence of digits that can "make" a buck. How much energy does that burn away across all the fails?
Then there's the design of server farms - put 'em next to the power generation facility to reduce voltage drop to the place. But there's no city there or anyone that can really use all the heat generated by the gigantic operation, so I guess it just all goes out the tailpipe for the polar bears to make use of.
Absolutely!
I just didn‘t wanted to start with all and every guzzler there is.
Sure, video-streaming is certainly alot a heftier consumer, and crypto-currency is probably the worst idea since the atomic bomb (and now, as if it hadn‘t been enough, „they“ begin to create NFT-art, raking in fortunes for having those server-farms cooking.)
Ok. Enough. Even if I think it’s ill-dated, it’s reality and we have to come around…
I‘ll still won’t stream.
[emoji1590][emoji4]
We don't have polar bears in Scandinavia or Finland, but extra heat is stored and used tho very high%
Utilizing data center waste heat in district heating – Impacts on energy efficiency and prospects for low-temperature district heating networks - ScienceDirect
Data center heats homes: Yandex sells server waste energy to district heating | Metropolitan.fi
https://www.mdpi.com/2071-1050/10/4/939/pdf
etc.
