Hello All,
I am curious if anyone has auditioned a pair of Klipsch RP-600m speakers with a single ended tube amplifier between 4 and 10 watts per channel and what were the results.
Take a look at:
Klipsch Reference Premiere RP-600M loudspeaker | Stereophile.com
Quote:" With my First Watt SIT-3 power amplifier (18Wpc) driving the Klipsch RP-600Ms"
"JA measured 89.6dB/2.83V/m"
"This effect was most obvious with a 22Wpc single-ended 845 tube amplifier"
"The Klipsch Reference Premiere RP-600M is not just a great loudspeaker for its price, or for horn-loving Klipsch Kids—it's way better than that."
"Overall, and that lively enclosure aside, the Klipsch Reference Premiere RP-600M offers impressive measured performance, especially when its affordable price is taken into account.—John Atkinson"
My opinion is: go for it! but choose a good SE amplifier not less than 12 watts et will be great in a small room.
Take a look at:
Heh, 10 watts was the said limit. Usually going over that is difficult to do with an SE design, unless you go with big tubes like an 845 and I am not messing with those voltages. I think I should be good if the speaker is about 4 - 6 feet from my ears with wattage range. I just wanted to hear from those that have actually done it and what the results were.
Klipsch RP-600M with SE Amps
I have home-built open baffles/boxes in my shop and office which use Eminence Beta 12LTAs and Eminence horn-loaded super-tweeters with 6dBa 1st-order (Butterworth) cross-overs and some very mild padding on the tweeter. Efficiency of these speakers is pretty high; likely 96-97 dBA/watt, since little energy is lost in the cross-overs or in fighting the air in an enclosed speaker. The downside, of course, is that room placement is super-critical. However, the sound is incredibly lifelike with a HUGE soundstage IF placed correctly.
HOWEVER, I also have two pairs of Klipsch RP-600Ms (don't ask) that I have been experimenting with.
I am using two SE amps: (1) stereo TubeLab TSE-II with # 45 SETs, and (2) a pair of TSE-II 300B monoblocks. Running the 45s on the cool side, so probably putting-out 1-3/4W per channel. The 300Bs are doing about 6.5 to 7 watts out, I reckon. Haven't measured either, but these educated guesses probably aren't far off.
I've tried both amps with stock RP-600Ms AND with a clone of the GR Research cross-over, which is 1st order on both tweeter and woofer, PLUS a C-L notch filter across the woofer. The polarity of the tweeter is reversed at the moment, but not sure if that makes an audible difference.
The stock RP-600Ms are noticeably "scooped" in the mid-range. This is NOT necessarily a "bad" thing, as it depends on your ears and musical style.
Klipsch is effectively recreating the famed "BBC dip" which favors highs and lows at the expense of the mid-range; the BBC found that most people prefer that sound. For example, my son-in-law tweaks his vintage Marantz receiver by raising the treble and bass and lowering the mid-range tone control; voila, the BBC dip.
BBC Dip
I prefer the flatter response of the GR-style crossover. It IS however a subtle difference which will be most apparent to folks who are listening for DETAIL, i.e. High Fidelity = "true" sound reproduction.
The RP-600Ms do WORK with the 45 amp, but the lack of power is quite noticeable, even with the crossover mod.
The RP-600Ms work REALLY well with the 300Bs, although I sense that they would work MUCH better with slightly more power, e.g. a small P-P tube amp. I have an old DYNACO SCA-35 on the bench which is an EL-84 with quite famous ULTRALINEAR OPTs. I suspect THAT amp will hit the sweet-spot for the RP-600Ms...
SO these speakers will WORK with a DHT SE tube amp, but with a REAL WORLD efficiency near 90 dbA (not the 96 that Klipsch suggests) I think you realistically need around 10 watts per channel.
I would suggest trying an EL-84 push-pull amp; there are lots of cheaper designs (e.g Heathkit, EICO, etc) than the Dynaco, but personally I really like the Ultralinear design, esp biased a little cold and with MINIMAL feedback (that is, beyond the Ultralinear connection, which somebody is sure to point-out IS a form of feedback, but of course NOT GLOBAL feedback, which I dislike). The Big Difference: really good P-P iron a MUCH cheaper than really good SE iron, so it's a good place to start.
TubeLab has a Simple P-P board that would work, although I haven't built one...
You COULD try TubeLab's SSE design using say KT-88s at >400 vdc B+ through 3K OPTs; that would be cheaper to build, AND get you up around the power of the 300Bs, and would probably drive the RP-600Ms decently. I have a TubeLab SSE in the shop which uses KT-88s (altho KT-66s in there now). I'll try the Klipsches with that amp to see what it sounds like, but it will be a month or so...stay tuned.
BBC Dip
PS you CAN get 10W out per channel with say PARALLELED 300Bs, but unless you've matched the tubes pretty precisely, I find that Parallel SE is a fool's errand.
Hareynolds, have you got a circuit diagram of the GR XO clone for the TO 600s?
