Looking for a few metres each of red, black / blue and white for power supply wiring.
Can't seem to find supply of small runs of decent wire in UK. Ebay has silly prices pre metre.
Please PM. Thanks in advance
I might have many metres of really good quality Alphawire silver coated copper with ptfe insulation. (1000ft) However only in black and red... Will check what dimensions (awg they are).
These:
https://eu.mouser.com/Wire-Cable/Ho...0xg1gZ1z0xf2q&Keyword=alpha+wire+5876&FS=True
EDIT: 20awg ptfe alphawire it is.
These:
Vendor I bought from recently, it was delivered in a few weeks
UL1332 Polytetrafluoro Stranded Electronic Wire 12AWG-28AWG Tinned Copper FEP | eBay
This is Amazon USA but CERTAINLY same or equivalent must be available in UKLooking for a few metres each of red, black / blue and white for power supply wiring.
U$37 for TEN rolls, different colours, 25ft per roll, perfect for Hobby use.
https://www.amazon.com/Remington-In...=1&keywords=20+awg+wire&qid=1618420567&sr=8-2
Less than 50 US cents a meter.
Wire is cheap and readily (sort of 🙂 available, so why not use the best one can obtain for a reasonable price. Try teflon wire insulation when you solder/ pre-tin these wires and then come back and tell me it ain't worth it vs that plastic (PVC) stuff. PVC is used because it is cheapo for a mfg who really does not care about wire quality. I was turned on to telfon wire when I was a green tech working at Motorla comm. I still have some of it I borrowed for projects. Eek hot PVC 🙂
I think I might have convinced Bob Cordell who was against it too, I sent him some to try out, he gave it a thumbs up
I have used the TE/Raychem hookup wire for a while now and I like it.
i.e. https://www.mouser.ca/datasheet/2/418/1/NG_CD_55A0811_AA-681650.pdf
Raychem has lots of options (Tin coated, Ag coated, etc.)
Sold by the foot (at least in Canada), and well priced.
Thanks for the tips guys, sometimes I forget to search here and a UK seller has some in various colours.
Bambadoo that alpha wire looks very good quality stuff.
How is the quality? Does it smell? I bought some from Amazon and the smell was so bad I had to return it.
- Design & Build
- Parts
- Does anyone have 20awg hook up wire?
