Hello.
I have tried to measure a 4 th. order cabinet without luck.
Anyone with Suggestion to a 4th order cabinet?
It's for 1pcs. Eminience Lab 12C subwoofer.
Thx.
Thx.
Those calculations don't take Le or semi-inductance into consideration, and would therefore likely result in a bandpass alignment that's tuned too low. If you're going to follow that site, make sure that it's easy to shorten the vent if necessary after the system's built.
I dont have the right liters. I have tried using hornsrep. But think I do it wrong.
Can anybody measure a cabinet for me?
Why 4 other, it’s because have 4 build into ceiling, and cabinet upstairs.
So no cabinet in the room.
It’s for cinema use🙂
Which program are u using?
I can’t figure out the front liters/liter behind speaker in the text?
Do you have drawing of cabinet?
Thank for all the help.
But I need a 3rd order and want to install in my floor, so that won't work.
Have you heard of the devastator? It's a bandpass/horn sort of thing. I haven't heard one but the lab12c models well in the devastator nano.
More info on avsforum:The Devastator Index | AVS Forum
Looks good with a 66hz 3rd order lowpass.
B0$3 Acoustic Wave Cannon concept, bend it per B0$3/the late DJK's half square wave antenna tweak for some extra performance: https://www.diyaudio.com/forums/subwoofers/9501-acoustic-wave-canon-6.html#post1175482
- Subwoofers
- Eminence Lab 12C 4th order cabinet
