Pin straightener 3d model
Anyone ever sketch up a pin straightener tool for 7 and 9 pin tubes? Looks like it would be a simple 3d print but searches turned up nothing.
My 1940's vintage 7 pin straightener has 8 holes, the 9 pin has 10 holes, pin straighteners don't account for the missing pin. with a micrometer it wouldn't be difficult to draw one up and machine it from some 3/4 inch aluminum bar stock on the CNC even with beveled entry holes. I'm sure an accurate diameter measurement is available so you wouldn't have to measure it, it is a standard. In CAD for stuff like this I just draw an 8 sided or 10 sided polygon of the diameter, then drag a circle snapped onto each vertex. Then size the holes to be very snug on the pins. Then delete the polygon. The holes would have to be peck drilled as an end mill that small in diameter is not available that long.
Even easier CNC run would be to machine it from Corian or a very dense wood like Lignum.
Here is a nice 1/4 inch thick fiberglass pin straightener I found on Ebay a couple of years ago. Can't find it now though.
