Help biasing Pioneer SA-8500II Phono stage
I installed new transistors in the AWF-023 Equalizer Amplifier board on the Pioneer SA8500II amp. I used the KSA992s and KSC1845s. The voltages on Q9 and Q10 are off a little and I wasn't sure if I need to change any of the bias resistor values? Also the current is at 4.1ma instead of 3.5ma. Not sure if it's off enough to matter? I have all the voltages marked on the schematic. Sorry the schematic is a little light.
Kennyg
