4" Full Range Transmission Line - Aucharm speakers
I give up to model my own TL design, cause the parameters from aliexpress might be wrong, so this could end up in a tradgey. I saw some people using Pensil or Frugal Horn MK3 have good results. But I think thery are too big, want something easy to carry, anyone have a suggestion of a design up to 50 cms of height?
thanks
OK… it is not overly suitable for vented, a 9 litre miniOnkne with high R vents works to knock the peak in the sim down, the other is 9 litre butterworth sealed with no damping. To get a significanrt drop in Q you have to go real big, up to 135 litres. So as long as sealed is at least 9 litres you can make it as large as you want. Pay attention to F6, F10, not F3.
Vented does not work larger (or very well with a tubular duct)
attachment.php
These are the appropriate miniOnkens that would be repurposed.
Classic Golden Ratio. These are freely available, choose one ill figure the vent details. CGR dFonken125
The next 2 would require a planset subscription.
Rectangular miniOnken.
Full-on Trapezoidal miniOnken.
dave
So I designed a TL Sl/So = 0.5, tunning to 50Hz. But I think the speaker is too close to the wood behind, there is any problem?
OK, a quick approximation in HR of your ML-TQWT [vented inverse tapered TL] yields a ~53 Hz Fp Vs the 1/4 WL calc'd. ~61 Hz and because it has so little net volume [Vb] it rolls off at ~2nd order [12 dB/octave] below 100 Hz, so not a bad design, just not 'fat' enough to go low.
Yes, ideally need at least 1.5x driver depth all the way around it and definitely at least cone depth.
You're welcome!
Understood, MJK prefers to use Bl instead of Qes, which no way to guess other than looking at the magnet size AFAIK [FWIW I used 72 Hz Fs, 0.64 Qes, 5.06 Qms, 3.66 Bl], when all we really need is Qts' for calculating a box size plus damping 'fudge' factor [4-10x Vas depending on Qts'], so while his alignment is technically the most correct from a sealed or BR alignment POV, it doesn't account for the extra volume required to add damping and still get a ~flat response down to Fs and why I use to describe his TLs as having all the 'fat' trimmed off my much larger ones. 😉
More like nightmares with post civil war Ga. rough cut yellow pine board siding, not to mention originally uncured [full] size lumber my 'stick built' house is constructed with. 🙁
Oh! Performance wise they're 'fabulous', like well damped iron construction and with those boxes full of probably a couple of thousand coins perched on top to mass load them they are certainly rigid/massive enough, but by the same token, a nightmare to plane flat/square, then trying to drill for blind screws.
Buzz has long since moved to a house where he says they sound even better [no surprise compared to an upstairs apt.], no doubt due somewhat to 'framing' a large stone fireplace and still gets a lot of praise, want to sell, etc., from everyone that hears them. Not too shabby for a pair of tweaked RS 40-1354s.
Reactions: rjbond3rd
