IN-9 Neon Bargraph for tube amplifier
I was looking at YouTube videos and discovered the IN-9 neon analogue bargraph that is current driven 0 to 18mA at around 110 volts.
One could make a sand free light display for a tube amplifier or preamp, possibly driving them with pentodes as the high plate resistance would be favourable. Easy to spice up a V to I drive using tubes.
Has anyone tried them?
Lovely IN-9 Bargraph nixie tube VU level meter ,Spectrum Analyzer - YouTube
NIEXIE audio spectrum analyser on IN-9 tubes - YouTube
IN-9 IN9 neon Nixie tube bargraph Indicator linear signal meter NEW | eBay
  • IN9-2.pdf
    IN9-2.pdf
Neon ?--it must have improved its gaseous composition as it is a noise producer and you are going to use them in an---audio amplifier ?
As I am used to their "effect " in radio communications I hope in this modern day and age somebody is going to say " neon?--- no problem now with "modern techniques" ??
Checking on upmarket electronic engineers websites it seems its "okay " as a power supply indicator on a front panel but definitely not as a circuit part of a quality audio amplifier.
Quote- why is it an issue ?- neon indicators/lamps electrodes are made from thoriated steel ( or somewhat like matter - Americium ) that is long life radioactive to stimulate emission from the cold cathode --the EU didn't like that --radio active .
Thank you for the post duncan2.
Thorium! I'm surrounded by the stuff 🙂, I have some old thorium gas mantles and some tungsten/thorium TIG welding electrodes used for testing my Geiger counters. Are the thoriated tungsten cathodes in transmitting tubes very radioactive? If I happen to break one I will have a sniff with a Geiger counter.
Americium, still have a few of the old style smoke detectors about, changing to Photoelectric types, last century when at school I remember our science teacher found a tube with a unipotential cathode that set a Geiger counter clicking, apparently some cathode coatings were mildly radioactive.
Are Welding Rods Radioactive? – WeldingBoss.com.
