The sound of A2 operation
The sound of A2
My Gm100 ran in the A2 class
Is this amplifier related to the NAT audio Magma? The FrankFrank output transformer looks like a custom part, I don't see any product number on the label in your picture. I've found good references about this transformer brand from Thailand on audio forums, but I never heard it myself and it seems to be not available anymore on large ecommerce websites. Is it expensive, and are you satisfied with the result?
About the UL/CE safety ... I guess that this kind of products should be classified as experimental devices, and sold with the matching safety sign and barriers ;-)
I've done A2 with an 826. Sounds great.
That's a beautiful tube! What plate dissipation are you running at? I can't imagine you are getting close to the 1kW rating!
Hi
Even the nat audio is not operate to 1kw pd 175w power is only used about 1/3 off max pd Your can run. It to 900w pd with higher ht and mor andode bias.
Exe the load impedance 1k vp 600v bias 100 ma the giant can signings with 6to8 watt power out put in negative bias mode If your run in positive grid bias the bias are rising to 300 or 500 ma get 20w power output buy the way a thd is to high too
Regard
