Wolfspeed/Cree C3M0350120D
I wonder what do you think of this SiC mosfet. Has a triode-like behaviour In a interesting current range and fairly affordable.
Should be interesting use for an amplifier, something like a F3, maybe?
Oon
There is no tride-ish behavior. All of the curves are concave down which is pentode-ish.
The LU1014D is the only device that I have found with triode-ish curves and not marketed as an SIT.
The topology in F3, as I understand it is, as Vgs increases, so does gain but at the same time, Vds decreases and that reduces gain. If done properly they would cancel out each other. At least that is in theory.
Besides, it is SiC and only a few bucks...
Oon
