ALIENO 250LTD amplifier
I've found an Italian company who offer an OTL valve amplifier.
The product page is this (translated in English by Google) :
Google Translate
I would read opinion from more expert users about this amplifier that is based on a single tube 300B for channel and that outputs 250W.
Consider the final phrase that states :
"ALIENO 250 LTD is not a hybrid tube & transistor amplifier!
The innovative LTD "Loudspeaker Tube Direct" technology allows the tubes to be used exclusively for the amplification circuits, while the transistors are used exclusively for power supply and protection circuits."
This sound very strange because the 300B tube anode current is in the range of hundreds of milliamperes, not capable to generate : "Output current: > 100 peak Amps per channel."
It's a hybrid, even though they say it isn't 😉. 250W
per channel into 3 ohms
About the hybrid hypotesis I've found another page where the amplifier is reviewed, at the end of the page there is a little schematic about internal circuit.
si audio041114
From that image it seems that the out signal of 300B is current amplified.
But considering that the out signal of 300B is the audio signal and that the output current is not DC but is true audio could not be true that transistors are not used in amplification circuits.
Relevant part of positiveday's link shown below. The 300B is in cathode follower configuration so is unlikely to be imparting much of its "character".
I think you are right, also if the original idea was to "replicate" the sound of a tube amplifier with a transistor amplifier all the amplification chain is useless. They could have used the output signal from the first tube the ECC82.
I find all the "product" a little unfair.
Do you think that avoiding the cathode follower circuit and using the signal on the anode with a resistor would be possible to reproduce a valve amplifier sound using transistors? In other words, it's possible for you to "amplify" a warm tube "sound" using transistors?
A simpler solution is to make a preamp with a bit of 2nd harmonic distortion and put it into a class 'D' amp. I think you feel your getting something with a 300B. Find some old style valves with some good glow and hide the 'D' amp underneath.
