Faulty power supply stage
Hello Friends.
I have an Adcom GFP-555 where the power light comes on but there is no sound from any of the outputs.
The output relay does not toggle.
The power LED comes on.
I've obtained the schematic and from what I measure it looks like there is a fault in the power stage.
I've attached the relevant section, my measurements are in red.
Nothing on the board looks burnt.
From looking at the measure points, what would the best course of action be to fix this?
Thanks!
Have you checked the resistors around q901 /902? They are not getting “turned-on” so you are missing voltages to turn on the next stage of transistors.
If the resistors measure good, then check q901/902, as the next likely thing is one or both are defective.
Hazy thinking... what would a short across C910 or C912 do (or an open resistor feeding them).
The positive rail would not come up, the negative would try to rise but just turn on Q903 and clamp the negative output rail to a low value... which you have.
A fruitful Monday morning saw my first successful electronics repair:
I pulled R's 901-906 and found R904 was opencircuit.
Also pulled Q's 901 and 902 but since they measured the same as each other I figured they were OK.
I daisy chained some resistors together to get the same value as R904 (3.3K) put it all back together and now it works. "Hell aint a bad place to be" sounds real good right now.
Thanks to you all in this forum for inspiration and tips!
Excellent :up: Fault diagnosis is always about gathering evidence (all the readings you provided) and then doing a bit of piecing together to try an make sense of it.
It might be worth replacing its opposite number in the upper half of the circuit.
Indeed, I now need to source the resistors and I do intend to replace both but seem to end up with a 50 cent shopping basket and $15 delivery fee.
Where do you guys in Melbourne/ Australia shop for electronic bits? I like the service at element14 but two resistors is not really worth the overhead.
3.32k seems also an odd value not in common kits.
I did try a 10k trumpet but found it impossible even to get the required value.
I can see why 😉
All that resistor does is provide the required base current for the series pass transistor and also (and importantly) it sets the current in the 12 volt Zener which is used as the reference... but the good news is that its not critical. As long as you have 'enough' current it will all work just fine.
