Philips User Processors MAB8441P (MAB 8441P, MAB8441) Data for Txxx Programming Code
In Philips vintage cd player models (so as in high grade brands like e. g. Krell, SAE, Proceed, Mark Levinson, Micromega) there are a often the MAB8441P in use but with a wide range of different programming codes.
In the meantime probably I have find out, that there are follow groups of different MAB's with mask programmable ROM:
1) MCU for Servo MAB8441P Txxx (for the servo PCB resp. servo section on main board with TDA 5707/5708 resp. TDA8807/8808 - most versions are "T012", "T062" and "T164" - maybe all forward compatibility resp. upward compatibility)
2) MCU for Display and control MAB8461P Wxxx (e. g. "W105" or "W079")
3) MCU for "Fav Track" selection MAB8421P Fxxx (a special feature to find in any few models)
4) MCU for Servo + Display and control (single MCU solution) e. g. MAB8441P "T105" and "T107"
Concerning the successor-MCU variants - probably also in mask programmable ROM version (mostly Motorola's SC/XC/ZC series) - I can't give a statement concerning differences.
Interesting is the fact, that in most service manuals Motorola's MC68HC05 series is to find in the part list,
But according the images of most main PCB's in a lot of CD player are to find one (sometimes more than one) IC from Motorola's SC/XC/ZC series.
On the web not only I don't find really helpful information regarded software data sheets - go to
https://archivedforum.beoworld.org/forums/t/25862.aspx
Maybe the Dutch company
https://www.bramjacobse.nl
is able anywhere to clone replacements for all CD Player MCU's - any few are already available, e. g. the examples from #17 and those under
https://www.ebay.com/itm/294024134898?_ul=BO
From a wide range of models based on Philips transport mechanism CDM1-4 (from previous repairs and from PCB images found on the web) I have try find out the used MCU's.
Of course, various reading errors cannot be ruled out - it may also be that the MCU ICs mentioned were only intended for certain batches, which means that other software versions were also used for the same model - i.e. different type designations for the ICs the ones I specified.
A) MCU IC's in CD player models with CDM-3 (>TDA1540)
KRELL MD-1 It's a Transport – SAA7210P MAB8441P T164 (Servo) CDM-3
KRELL MD-10 It's a Transport – SAA7210P CDM-3
LUXMAN D-500 2 x PCM1701P-K – SM5843AP CDM-3
LUXMAN D-500X’s TDA1541A-S1 (Single Crown) CDM-3
LUXMAN D-500X’s II TDA1541A-S1 (Single / Double Crown) CDM-3
MICROMEGA DUO.CD. Transport MAB8441P T162 (Servo) MAB8441P T018 (display processor same like in SAE's model "D103)" NSM4202A CDM-3/CDM-9 Pro
MICROMEGA TRIO.CD.2 It's a Transport – SAA7310GP CDM-3
STUDER A730 TDA1541A-S1 (Double Crown) CDM-3
B) MCU IC's in CD player models with CDM-1 and CDM-1/MKII (>TDA1540)
ALTIS AUDIO CDT 1 It's a Transport CDM-1/MKII
ARCAM DELTA 170 (serial < 2350) It's a Transport – SAA7210P ZC86606P (Display) CDM-1/MKII
ARCAM DELTA 170.2 (serial > 2350) It's a Transport – SAA7310GP CDM-1/MKII
ARCAM DELTA 170.3 It's a Transport – SAA7310GP ZC86606P (Display) MAB8441P T157 (Servo) CDM-1/MKII
AUDIOLABOR 531 PCM1702 CDM-1/MKII
BARCLAY DIGITAL CABERNET It's a Transport – SAA7310GP CDM-1/MKII
BARCLAY DIGITAL M1 CD It's a Transport CDM-1/MKII
CAMBRIDGE AUDIO CD3 4 x TDA1541A – SAA7220P/B MAB8441P T164 (Servo) CDM-1/MKII MAB8441P T062 NSM4202A
CAMBRIDGE AUDIO CD3M It's a Transport CDM-1/MKII
ELITE ELECTRONICS Jx2 TDA1541A CDM-1
EMT 981 BARCO PROFESSIONAL TDA1541A-S1 (Single Crown) MAB8441P T164 (Servo) CDM-1/MKII
GRUNDIG CD-9009 FineArts 2 x TDA1541A-S1 – CXD1244 CDM-1/MKII
B&O Beocenter 8000 9000 9300 8500 9500 CD control board: MAB 8441P T164 (Servo)
KRELL CD-1 CS4328-KP MAB8441P T164 (Servo) MAB8461P W105 (Display) CDM-1/MKII
KRELL CD-DSP 2 x PCM61P-J + Motorola XSP56001 CDM-1/MKII
KRELL CD-DSP Mk2 2 x PCM61P-K + Motorola DSP CDM-1/MKII
KRELL MD-2 It's a Transport – SAA7210P MAB8441P T164 (Servo) CDM-1/MKII
KRELL MD-20 It's a Transport – SAA7210P, MAB8441P T164 (Servo) MAB8461P W105 (Display) MAB8421P F050 CDM-1/MKII
(Krell MD-20)
http://bbs.hifidiy.net/thread-1289393-1-1.html (various Krell vintage CD Player models)
MARANTZ CD-12 It's a Transport CDM-1
MARANTZ CD75 II TDA1541A – SAA7220P/B CDM-1/MKII XC86618P
MARANTZ CD75 II SE TDA1541A – SAA7220P/B CDM-1/MKII XC86518P
MARANTZ CD-75DX TDA1541A – SAA7220P/B CDM-2 / CDM-4/11
MARANTZ CD-80 TDA1541A-S1 (Single Crown) XC409025P/SC409011P P111 CDM-1/MKII
MARANTZ CD-85 TDA1541A-S1 (Single Crown) XC68HC24P+MC68HC11A0P CDM-1/MKII
MARANTZ CD-94 TDA1541A – SAA7220P/A SAA7210P/M4804A MAB8441P T082 "M80C51F-121 HC11017262" (OKI) CDM-1
MARANTZ CD-94 Mk II 2 x TDA1541A-S1 (Single Crown) "M80C51F-121 HC11017262" (OKI) CDM-1
MARANTZ CD-95 2 x TDA1541A-S1 (Single Crown) CDM-1
MARANTZ CD-95DR It's a Transport – SAA7210P CDM-1
MARANTZ CD-99DR It's a Transport – SAA7210P CDM-1
MARANTZ CD-99SE 2 x TDA1541A-S1 (Single Crown) CDM-1
MARANTZ CD-99SE Limited 2 x TDA1541A-S1 (Double Crown) CDM-1
MARANTZ CD880J TDA1541A-S1 (Single Crown) CDM-1/MKII
MCINTOSH MCD7007 TDA1541A-S1 (Single Crown) MAB8441P T164 (Servo) MAB8461P W079, MAB8421P F050, CDM-1/MKII
MICROMEGA TRIO.CD. It's a Transport CDM-1/MKII
MICROMEGA CD F1 Premium TDA1541 SAA7220P/B MAB8441P T082 (Servo) CDM-1/MKII / CDM-4/26
MICROMEGA "SOLO H" SAA7310GP SAA7321GP MAB8441P T164 (Servo) MAB8441P T018 (Display) NSM4202A, CDM-4/25
MICROMEGA "DUO" (Transport) SAA7310GP MAB8441P T162 (Servo) MAB8441P T018 (Displaypr wie SAE D103) NSM4202A, CDM-9pro
MICRO CD-M2 (Marantz CD94, Philips CD960) TDA1541 CDM-1
MICRO CD-M100 TDA1541A-S1 (Single Crown) CDM-1
MICRO CD-M2000X TDA1541A-S1 (Single Crown) CDM-1
MUSEATEX MELIOR CD-D It's a Transport – SAA7310GP CDM-1/MKII
PHILIPS CD-80 TDA1541A-S1 (Single Crown) CDM-1/MKII
PHILIPS CD-85 TDA1541A-S1 (Single Crown) CDM-1/MKII
PHILIPS CD304 Mk II TDA1541 – SAA7220P/A – SAA7210P CDM-1
PHILIPS CD880 TDA1541A-S1 (Single Crown) CDM-1/MKII
PHILIPS CD960 TDA1541 – SAA7220P/A – SAA7210P CDM-1
PHILIPS CDD882 It's a Transport – SAA7210P CDM-1/MKII
PHILIPS CDV496 TDA1541A – SAA7220P/B – TDA1542 CDM-10
PHILIPS LHH1000 TDA1541A-S1 (Single / Double Crown) CDM-1
PRIMARE 204 CD 2 x PCM58P – SM5803APT CDM-1/MKII
PROCEED MRC100 2 x PCM58P – SM5813APT MAB8441P T164 (Servo), U3090MG, Futuba FV112 (VFD) MAB8461P W105 CDM-1/MKII
PROCEED MRC300 2 x PCM58P – SM5813APT – YM3623B U3090MG, Futuba FV112 (VFD) MAB8461P W105 CDM-1/MKII
PROCEED PCD 2 x PCM58P – SM5813APT – YM3623B CDM-1/MKII
PROCEED PCD2 2 x PCM58P – SM5813APT – YM3623B MAB8441P T164 (Servo), U3090MG, Futuba FV112 (VFD) MAB8461P W105, CDM-1/MKII
PROCEED PCD3 2 x PCM63P-K – SM5803APT – CS8412-CP CDM-1/MKII
PROCEED PDT It's a Transport – SAA7210P CDM-1/MKII
PROCEED PDT2 It's a Transport – SAA7210P MAB8441P T164 (Servo), U3090MG, Futuba FV112 (VFD) MAB8461P W105 CDM-1/MKII
PROCEED PDT3 It's a Transport – SAA7310GP CDM-1/MKII
RADFORD WS1 TDA1541A-S1 (Single Crown) SAA7210P, SAA7220P, MAB8441P T157, XC86606P CDM-1/MKII
(PHILIPS CD-782 TDA1541 MAB8441P T113 / MAB8441P T120 MC6805L8/XC86606P/XC86608P TDA1541 – SAA7220P/A CDM-4/11)
PHILIPS CD-304 TDA1540 MAB8440P, C042 (Servo-Proz.) MAB8420P, C033 (Displayproz.) CDM-1
PHILIPS CD-304 MkII TDA1541 MAB 8441P, T016 (Servo-Proz.) MAB8420P C033 (Displayproz.)CDM-1
REVOX B 126 TDA1541A – SAA7220P/B CDM-1 / CDM-4/27
REVOX B 226 TDA1541 – CDM-1
Continued in post #18
This is a mask-programmable ROM controller. According to the datasheet (attached) the ROM is programmed in the factory. This is the version code you encounter. It is unique for a specific function. I am not aware of any lookup table/information source for these versions. I ran into this myself while repairing a Cyrus AM/FM tuner. I ended up writing my own firmware...
These controllers were available as spare parts from (apparently also) ASWO and others. They also rarely fail, usually they get locked up in some unexpected mode due to an unhandled/unforeseen combination of inputs or other bugs. As for spares, if they are indeed faulty you're dependant on old stock. I got lucky with a failed NEC controller in a Technics amp. A NOS one from an obscure source solved the issues completely.
You could have a go at MFBFreaks forum as there is a lot of Philips-specific information around.
good advive:
MAB microcontroller versie overzicht - MFBfreaks.com
The efforts are only for the aim to find replacement devices in used condition to get the same device for the case, when it is necessary.
In the moment I need for Micromega top-loaders replacement cheap cd player models. In use are the follow:
Micromega SOLO mit CDM1-MKII/CDM4/25:
1) MAB 8441P T018 (Operating Unit/front PCB)
2) MAB 8441P T164 (Servoprozessor board)
3) SAA7310GP/SAA7321GP
Micromega DUO mit CDM9-pro:
1) MAB 8441P T018 (Operating board/front PCB)
2) MAB 8441P T162 (Servoprocessor)
Other devices with this versions:
NSM PickUp Driver Board:
1) MAB 8441P T018 (operating section)
2) MAB 8441P T164 (servo units TDA5708/TDA5709)
Krell CD-DSP
MAB 8441P T164
MAB 8441P T164 - go to one of the pictures under
CD Control Board for Beocenter 9500
GRUNDIG CD 35 (not CD-35X):
2xTDA1540P – SAA7030 CDM-2/10 MAB8441P-T018
Concerning this the MAB versions T162/T164 are not in use in single cd player models with loader/tray - this means only hifi consoles, music centers, hifi systems and ghetto-blasters equipped with CDM1-CDM9 (maybe with front loader but without loader with tray) uses this programmable version.
Where is such an overview/model list in the kind of those from the URL as follow ?
CD-Player-DAC-Transport List
How did you go tiefbassuebertr ?
Any news from Dutch Audio Classics people?
I am working on this Cambridge Audio which has two of them, T065 and T082 variety and they might be cooked. I wanted to get some just in case without realising that they are programmable...
Please keep us updated.
Roman
Has anyone been able to find more on the Txxx program versions and possible backward/forward compatibility? A friend of mine and I have an PHILIPS CD304 (MK I) that needs the IC replacement; funny thing - on the board is the MAB8441P-T016, while the service manual states that MAB8440P-D060 is used (!)
I can still remember that Philips had released numerous updates (Service Bulletin, sometimes called "Revision Manual") for authorized dealers after the service manual was already published.
Service-manuals without this information are not always helpful.
https://nanocamp.de/12-revision/philips-cd304-revision-manual.pdf
That T016 must be a bugfix version. There may be a service manual erratum listing that version. Or even a part number that is identical so when you would order the old chip you get the new one. AFAIK there is no manufacturing information about mask versions and their purpose except for the thread in MFBFreaksforu.
Interesting to know.
In order to the age of this information it isn't to understand, why Philips and Motorola are still not releasing them.
Than T for that link.
From this manual, I followed a link to page:
dindiki audio with CDM-1 TDA1540 TDA1541.
What a wealth of service info there!
And a lot of nice products like belt kits, remote controllers for old players, streaming inputs for TDA-1540 & TDA-1541.
Wehnever I can, I'll be purchasing belts from them to support them.
Thanks again
Roman
this thread seems to be interesting for translate (google language tools don't work good enough):
http://bbs.hifidiy.net/thread-540709-1-1.html
T,
Get yourself a Vivaldi browser and in there, there is an option to translate from "any to any" language.
In this case, Simplified Chinese to English works reasonably well and is quite readable.
Vivaldi is a browser written by people from Telecom Norway who brought us the best browser ever, the Opera (after it was sold).
Originally the aim was to re-create best features of the Original Opera (which every other browser copied), but now, they - as they did before - invent all these new features for the competition to follow.
Cheers
Roman
Under the URL
https://www.ebay.de/itm/295509901110
there is a replacement offer for no longer available mask programmable user processors (MAB8441P series Txxx) used in various Philips cd player models.
Here the address:
Jeroen Maximiliaan Fortanier, Charlotte van Pallandthof 47
1628 ZH Hoorn Nh
Netherlands +31-629173299
https://www.bramjacobse.nl/wordpress/?p=6773
There will probably be further offers for unavailable processors in this kind (for vintage CD players) in the future.
check out also his threads:
https://www.diyaudio.com/community/search/1539758/
Continued from post #1
C) MCU IC's in CD player models with all versions of CDM-2, CDM-4 and CDM-9 (>TDA1540) (except Technics, TEC, Toshiba, Philco and Philips)
3A ELECTRONIC C-160R TDA1543 MAB8441P T107 CDM-4
3A ELECTRONIC CD 2000 TDA1543 CDM-4
ACOUSTIC RESEARCH CD-06SE TDA1541A ZC86606P/XC86606P CDM-4
ACOUSTIC RESEARCH CD-07 SAA7350GP – SAA7220P/B CDM-4/19
ACOUSTIC RESEARCH CD-06 TDA1541 ZC86606P CDM-2
AIWA DX-M45 TDA1541A – SAA7210P MAB8441P T105 CDM-4/14 / CDM-4/25
https://www.diyaudio.com/community/attachments/dxm45board-jpg.292274/
GRUNDIG CD 8100 MAB8441P-T105 (Servo+Bedienteil+Display) TDA1541 – SAA7210P CDM-2/29 / CDM-4/11 Display: NSM4202A
ANALOG RESEARCH CD TDA1541 – SAA7220P/A CDM-2 / CDM-4/11
ANALOGIC DESIGN GROUP (Scott Nixon) 560 TDA1541 CDM-2/10 / CDM-4/25
AMC CD6 ZC99685P SAA7323GP – SAA7220P/B CDM-4/19
AMC CDM7 ZC99696P SAA7323GP CDM-4/19
ARCAM ALPHA TDA1541A – SAA7220P/B CDM-4/19
ARCAM ALPHA PLUS TDA1541A – SAA7220P/B CDM-4/19 XC/ZC processor
ARCAM DELTA 70.2 TDA1541A-S1 (Single Crown) CDM-4/11 / CDM-4/31
ARCAM DELTA 70 TDA1541 – SAA7220P/A CDM-2
ARCAM DELTA 70.3 SAA7350 + SAA7321 CDM-4
ARISTON CD PLAYER TDA1541A-S1 (Single Crown) CDM-4/19
ARISTON CD3 MAXIM TDA1541A-S1 (Single Crown) CDM-4/19
ARISTONA CD1380 TDA1543 – SAA7220P/A CDM-4/19
ARISTONA CD1482 TDA1543 – SAA7220P/A CDM-4/19
ARISTONA CD1006 TDA1541 CDM-2
ARISTONA CD1471 TDA1541-R1 – SAA7220P/A CDM-2 / CDM-4/11
ARISTONA CD4006 TDA1541 – SAA7220P/A CDM-2/10
Bang & Olufsen Beogram CD3500 TDA1541 – SAA7220P/B CDM-4/11
Bang & Olufsen Beogram CD4500 TDA1541A – SAA7220P/B MM5450N CDM-4/11 / CDM-4/19
Bang & Olufsen Beogram CD6500 TDA1541A – SAA7220P/B CDM-4/11
Bang & Olufsen Beogram CD7000 TDA1541A – SAA7220P/B CDM-4/11 / CDM-4/31
Bang & Olufsen Beogram CDX2 TDA1541 – SAA7220P/A CDM-2/10
Bang & Olufsen Beogram CD3300 TDA1541 – SAA7220P/A CDM-2/10
Bang & Olufsen Beogram CD5500 TDA1541A – SAA7220P/B CDM-2/29 / CDM-4/11
BLAUPUNKT CP-2850 TDA1541 – SAA7220P/A CDM-2/10 / CDM-4/11
California Audio Labs Aria TDA1541A – SAA7220 CDM-2 / CDM-4/11
California Audio Labs Tempest II TDA1541 – SAA7220P/A CDM-4/11
California Audio Labs Tercet TDA1541A – SAA7220P/B CDM-2 / CDM-4/11
California Audio Labs Aria Delta TDA1541 – SAA7220P/A CDM-2
CAMBRIDGE AUDIO CD2 4 x TDA1541 – SAA7220 CDM-2/10 / CDM-2/29
CAMBRIDGE AUDIO CD2 SAA7210P, SAA7220P 4xTDA1541, MAB8441P T082 (Servo) MAB8441P T065 (Display) CDM-4/11
Cary Audio Design CAD-855 TDA1541A – SAA7220P/B CDM-4/19
Conrad-Johnson DF-1 2 x TDA1540P – SAA7030 CDM-2 / CDM-4/28
Conrad-Johnson Sonographe SD-22 SAA7321GP CDM-4/19
CREEK CD60 TDA1541A-S1 – SAA7220P/B XC409032P CDM-4/14
DIORA CD-502 TDA1543 CDM-4
Deltec Precision Audio (DPA) T1 It's a Transport CDM-4/19
DUAL CD 5150 RC TDA1541A – SAA7220P/B MC68HC05C8/SC20610P, TMS3763CNL CDM-4/19
DZU CD482 TDA1543 – SAA7220 CDM-4/19
ERRES CD1371 (Philips CD371) TDA1541 MC68HC05C4/SC93416/ZC93486, NSM4202A, CDM-2/29 / CDM-4/11
ERRES CD1380 TDA1543 – SAA7220P/A MC68HC05C8-P104/MC68HC05C8-P105/XC99659P, CDM-4/19
ERRES CD1471 (Philips CD471) TDA1541-R1 – SAA7220P/A, ZC93486P, CDM-2 / CDM-4/11
ESTi ES-01AOOA It's a Transport SAA7310GP CDM-4
https://www.gzhifi.com/xinyi/goods.php?id=435
ETA model 2474 (Philips/Tesla CD482) TDA1543 – SAA7220P/B CDM-4/19
GRUNDIG CD 35 2xTDA1540P – SAA7030 OKI M2128-15, 5Z054Y (Servo-Proz.) CDM-2/10 MAB8441P-T018 (bedienteil)
GRUNDIG CD 35X/CD8100 MAB8441P-T105/T107 (Servo+Displ+Operating Unit) 1 x TDA1541 – SAA7210P CDM-2/29 / CDM-4/25 Display: MSM4202A
http://www.goldfinch-mod.eu/CD/grundig%20cd%208100/grundig8100.html
GRUNDIG CD-903 FineArts MAB8441P T082, MAB8461P W062 TDA1541A-S1 – SAA7220P/B CDM-2 / CDM-4/16
GRUNDIG CD 8400 Mk II MAB8441P T082 TDA1541A – SAA7220P/B CDM-2 / CDM-4
GRUNDIG CD-9000 FineArts MAB8441P-T082 (Servo-Proc.) MAB8461P W062 (Display-Proz.) TDA1541–SAA7220P/A CDM-2/29+4/11
GRUNDIG CD 30 2 x TDA1540D – M4551 (SAA7030) CDM-0
GRUNDIG CD 35X/CD8100 MAB8441P-T105/T107 (Servo+Displ+Bedienung) 1 x TDA1541 – SAA7210P CDM-2/29 / CDM-4/25 Display: MSM4202A
GRUNDIG CD 301 TDA1543 – M50423P CDM-4/19
GRUNDIG CD 303 TDA1543 – SAA7220P/B CDM-4/19
GRUNDIG CD 3000 TDA1543 – SAA7220P/B CDM-4/19
GRUNDIG CD 5200 TDA1543 CDM-4/19
GRUNDIG CD 5500 TDA1543 – SAA7220P/B CDM-4/19
GRUNDIG CD 7500 2 x TDA1540D – SAA7030 CDM-0
GRUNDIG CD 7550 2 x TDA1540P – SAA7030 CDM-1
GRUNDIG CD 8100 MAB8441P-T105 (Servo+Operating-Unit/RC+Display) TDA1541 – SAA7210P CDM-2/29 / CDM-4/11 Display: NSM4202A
GRUNDIG CD 8150 TDA1543 CDM-4/19
GRUNDIG CD 8200 TDA1541 – SAA7220P/A CDM-2/10 Display: NSM4202A
GRUNDIG CD 8400 TDA1541 – SAA7220P/A CDM-2/10 / CDM-2/29
GRUNDIG CD-9000 FineArts MAB8441P-T082 (Servo-Proc.) MAB8461P W062 (Display-Proc.) TDA1541–SAA7220P/A CDM-2/29 CDM-4/11
HEMA CD-2019 TDA1541 – SAA7210P CDM-2/10
INKEL CD-2000R TDA1541 – SAA7220P/B MAB8441-T082 CDM-2 / CDM-4
Kinergetics Research KCD-20 (Old) 2 x TDA1540P – SAA7030 CDM-2/10
Kinergetics Research KCD-30 TDA1541A CDM-2/10 / CDM-4
Kinergetics Research KCD-40 (Old) 4 x AD1860N-K – CXD1144B CDM-2/10
Kinergetics Research KCD-20 (New) XC99659P TDA1541A-R1 CDM-4/19
Kinergetics Research KCD-40 (New) XC99659P 4 x AD1860N-K – CXD1144B CDM-4/19
Kinergetics Research KCD-55T It's a Transport – SAA7210P CDM-4/19
KRELL DT-10 It's a Transport – SAA7310GP CDM-4/36 Pro Metallic
LECTOR CDP 1T TDA1541A CDM-2 / CDM-4
LECTOR CDP 2T TDA1541A-S1 (Single Crown) CDM-4
LECTOR DIGIDRIVE It's a Transport CDM-4/19
MAGNAVOX CDB460 TDA1541 – SAA7220P/A CDM-2/10
MAGNAVOX CDB465 TDA1541 – SAA7220P/A MAB8441P T082 CDM-2
MAGNAVOX CDB470 TDA1541 – SAA7210P MAB8441P T105 CDM-2
MAGNAVOX CDB471 TDA1541 – SAA7220P/A CDM-2
MAGNAVOX CDB472 TDA1541 – SAA7220P/A CDM-2
MAGNAVOX CDB473 TDA1541 – SAA7220P/A XC86604P, MAB 8441P T113, X2816BP 24 pin CDM-2 / CDM-4/11
MAGNAVOX CDB560 TDA1541 – SAA7220P/A CDM-2
MAGNAVOX CDB650 TDA1541 – SAA7220P/A CDM-2/10 / CDM-2/29
MAGNAVOX CD2000 TDA1543 CDM-4/19
MAGNAVOX CDB260 TDA1543 CDM-4/19
MAGNAVOX CDB262 TDA1543A CDM-4/19
MAGNAVOX CDB480 TDA1543 CDM-4/19
MAGNAVOX CDB482 TDA1543 – SAA7220P/A CDM-4/19
MAGNAVOX CDB492 TDA1543 SC39655P CDM-4/19
MAGNAVOX CDB500 TDA1543 CDM-4/19
MAGNAVOX CDB502 TDA1543 – M50423FP CDM-4/19
MAGNAVOX CDB582 TDA1541A – SAA7220P/B CDM-4/19 XC99659P
MAGNAVOX CDB600 TDA1543 – SAA7220 CDM-4/19
MAGNAVOX CDB610 TDA1543 – SAA7220P/A CDM-4/19
MAGNAVOX CDB630 TDA1541A – SAA7220P/B CDM-4/19
MARANTZ CD-11LE 2 x TDA1547 – SAA7350GP – SM5803APT CDM-4/36 Metallic
MARANTZ CD-11 Mk II 2 x TDA1547 CDM-4/36 Metallic
MARANTZ CD-10 TDA1547 MC68HC11A0P-C95N, MC68HC24P-285 SAA7350GP – SM5803APT CDM4/36 Metallic
MARANTZ CD-15 2 x TDA1547 – SM5803APT – SAA7350 CDM-4/36 Metallic MC68HC11A0P-C95N, MC68HC24P-285
MARANTZ CD-16 2 x TDA1547 – SM5803APT – SAA7350 CDM-4/36 Metallic MC68HC11A0P-C96N, MC68HC24P-28S
MARANTZ CD-16SE 2 x TDA1547 – SM5803APT – SAA7350 CDM-4/36 Metallic
MARANTZ CD-32 SAA7350 – SM5840FP CDM-4/19
MARANTZ CD-23 MC68HC05CB 2xTDA1547 CDM9-pro
MARANTZ CD-40 TDA1541A-R1 – SAA7220 MC68HCT05CBP/ZC99700P CDM4/19
MARANTZ CD-41 SAA7321GP CDM-4/19
MARANTZ CD-42 SAA7350GP, SAA7310GP, ZC400005P, X24C16P, MIC4264P15 PCF2705P (SPDIF) SM5840P CDM-4/19
MARANTZ CD-42 MK-II ZC400005P SAA7350 SM5840FP CDM-4/19
MARANTZ CD-50 TDA1541A SAA7220P/B, XC400007P (like CD40, but variable output) CDM-4/19 Composite
MARANTZ CD-52 SAA7350GP o. SAA7321GP – SM5840FP CDM-4/19
MARANTZ CD-52 mk II SAA7350GP – SM5840FP CDM-4/19
MARANTZ CD-52SE SAA7350GP CDM-4/19
MARANTZ CD-56 TDA1541 SAA7220P/A MAB8441 T012 (CDM-2/10 Servo Board), MAB8441 T082 (Display+Operating Instructions+Remote control)
MARANTZ CD-60 SE TDA1541A – SAA7220P/B CDM-4/19 Composite
MARANTZ CD-60 TDA1541A SAA7220P/B ZC400005P (like CD40, but variable output + headphone out) CDM-4/19
MARANTZ CD-62 SAA7350GP – SAA7322 CDM-4/19
MARANTZ CD-65DX TDA1541A – SAA7220P/B CDM-2/10 / CDM-4/11
MARANTZ CD-65 TDA1541 SAA7220P/A MAB8441P T041 (Display), MAB8441P T012 (CDM2 Servoproz.) CDM-2/10
MARANTZ CD-65mkII TDA1541A MAB8441P T146 CDM-4/19
http://www.diybuy.net/thread-1937163-1-1.html
MARANTZ CD72 SAA7350 CDM-4/19
MARANTZ CD72mkII SE SC409072CP, TDA1547 CDM-4/19
MARANTZ CD75 TDA1541 – SAA7220 MAB8441P T082, CDM-2/10
MARANTZ CD650 TDA1541 – SAA7220P/A CDM-2/10 / CDM-2/29 / CDM-4/25
MARANTZ CD873 TDA1541 – SAA7220P/A CDM-2 / CDM-4/11
Marantz CD273 TDA1541 – SAA7220P/A MAB8441 T012 (CDM-2/10 Servo Board), MAB8441 T082 (Display+Operating Instructions+Remote control)
MARANTZ CD273 SE TDA1541-S1 – SAA7220P/A CDM-2/29
MARK LEVINSON No 31 It's a Transport – SAA7310GP ZC89751P CDM-4 Ind Metallic
MCINTOSH MCD7005 TDA1541 – SAA7220P/A CDM-2/10
McCORMACK CD DRIVE It's a Transport SC409015P CDM-4/19
McCORMACK PRISM II TDA1541A-R1 – SAA7220P/B CDM-4/19
McCORMACK SIGNATURE CD TDA1541A-S1 (Single Crown) CDM-4/19
MERIDIAN 200 It's a Transport CDM-4/21
MERIDIAN 206 TDA1541A-S1 (Single Crown) CDM-4/21
MERIDIAN 206B TDA1547 (DAC7) – SAA7350 CDM-4/19
MERIDIAN 206 BS 2 x SAA7321 – SAA7350 CDM-4/19
MERIDIAN 206 DS CS4328-KS – SAA7310GP CDM-4/19
MERIDIAN 207 (16 Bit) TDA1541A-S1 (Single Crown) CDM-4
MERIDIAN 208 2 x SAA7321GP CDM-4
MERIDIAN 500 It's a Transport CDM-4 / CDM12
MERIDIAN 506 CS4328-KS – SAA7310GP CDM-4 / CDM12.4
MERIDIAN 602 It's a Transport CDM-4/21 / CDM-4/36
MISSION DAD5 SAA7321GP – SAA7310GP XC400012P CDM-4/19
MICROMEGA CD F1 Pro TDA1541 MAB8441P T082 CDM-2 / CDM-4/11
MICROMEGA CD F1 Digital It's a Transport – SAA7210P CDM-1/MKII
MICROMEGA CD F1 Pro TDA1541 CDM-2 / CDM-4/11
MICROMEGA CD F2 TDA1541A – SAA7220P/B CDM-4/11 / CDM-4/25
MICROMEGA DUO.CD. Transport MAB8441P T162 (Servo) MAB8441P T018 (Displayproz., wie SAE D103) NSM4202A CDM-3/CDM-9 Pro
MICROMEGA "DUO" CD3 (Transport) SAA7310GP ZC400012P, CDM-9/45
MICROMEGA DIGIT TDA1541A-S1 (Single Crown) CDM-4/19
MICROMEGA JUNIOR TDA1543 CDM-4/19
MICROMEGA LEADER SAA7321GP CDM-4/19
MICROMEGA LOGIC SAA7321GP CDM-4/19
MICROMEGA OPTIC SAA7220P TDA1541A-S1 (Single Crown) XC99659P CDM-4/19 Composite
MICROMEGA OPTIC.BS. SAA7321GP CDM-4/19
Mission PCM-II TDA1541A-S1 – SAA7220P/B, MAB 8441P T164 (Servo), MAB8461P W127 (Display) CDM4/11
MISSION PCM4000 TDA1541 – SAA7220P/A CDM-2/10
MISSION PCM7000 TDA1541-S1 – SAA7220P/A CDM-2/10
MOD SQUAD PRISM TDA1541 – SAA7220 CDM-2
MOD SQUAD PRISM II TDA1541A-R1 – SAA7220P/B CDM-4/19
MOD SQUAD SIGNATURE TDA1541A-S1 (Single Crown) CDM-4/19
MUSICAL FIDELITY CD1 SAA7323GP – SAA7220P/B CDM-4/19
NAD 501 SAA7323GP ZC99696P, CDM-4/19
NAIM AUDIO CD1 ZC99685P TDA1541A-S1 (Single / Double Crown) CDM-4/27 / CDM-9 Pro
NAIM AUDIO CDS TDA1541A-S1 (Single / Double Crown) ZC99685P CDM-4/25
ORELLE CD-10T It's a Transport CDM-4/19
ORELLE CD-100 TDA1541A-S1 (Single Crown) XC99659P, CDM-4
ORELLE CD-100SE TDA1541A-S1 (Single Crown) CDM-4/19
ORELLE CD-160 TDA1541A-S1 (Single Crown) CDM-4/19
ORELLE CD-160.2 TDA1541A-S1 (Single Crown) CDM-4/19
ORELLE CD-480 TDA1541A-S1 (Single Crown) CDM-4/19
PROTON AC-300 2 x TDA1540P – SAA7030 CDM-2 / CDM-4
PROTON AC-300 Mk II SAA7210P, SAA7220P, TDA1541 MAB8441P T107 CDM-2 / CDM-4/19
PROTON AC-620 TDA1541A – SAA7220P/B CDM-4/19 Composit
QUAD 66 TDA1541A-S1 (Single Crown) XC99659P CDM-4
RADIOLA CD1380 TDA1543 – SAA7220P/A CDM-4/19
RADIOLA CD1006 TDA1541 – SAA7220P/A CDM-2/10
RADMOR 5450 TDA1543A CDM-4/19
RESTEK RADIANT (ver. 2) TDA1541A-S1 (Single Crown) CDM-2 / CDM-4
REVOX B 226-S / E TDA1541A-S1 (Single Crown) CDM-1/MKII / CDM-4/26
REVOX C 221 2 x SAA7321GP / SAA7323GP CDM-1/MKII / CDM-4/27 / CDM-4/19
REVOX H 2 2 x SAA7323GP CDM-4
ROTEL RCD-820 TDA1541 – SAA7220P/A CDM-2
ROTEL RCD-820B TDA1541 – SAA7220P/A MAB8441P T082, CDM-2/10
ROTEL RCD-820BX TDA1541 – SAA7220P/A CDM-2
ROTEL RCD-820B TDA1541A – SAA7220P/B MAB8441P T082, CDM-4/11 / CDM-4/25
ROTEL RCD-820BX2 TDA1541A – SAA7220P/B CDM-4/11 / CDM-4/25
ROTEL RCD-855 TDA1541A – SAA7220P/B CDM-4/19
ROTEL RCD-865BX SAA7321GP MC68HC05C8-P110/ZC99685P CDM-4/19
ROTEL RCD-945AX SAA7341GP CDM-4/19
ROTEL RCD-955AX TDA1541A – SAA7220P/B SC99659P CDM-4/19
ROTEL RCD-965BX SAA7323GP, CDM-4/19
SAE D103 TDA1541 – SAA7220P/B MAB8441P T042 o.T082 (?), MAB8441P T018, CDM-2 / CDM-4
SCHNEIDER CD4006 TDA1541 – SAA7220P/A CDM-2/10
SYLVANIA CD1460 TDA1541 – SAA7220P/A CDM-2
SYLVANIA CD1465 TDA1541 – SAA7220P/A CDM-2
SYLVANIA CD1470 TDA1541 – SAA7220P/A CDM-2
SYLVANIA CD1473 TDA1541 – SAA7220P/A CDM-2 / CDM-4/11
SANSUI CD-X211E TDA1541A-R1 – SAA7220P/A CDM-4/19
SHANLING CD-T300 8 x PCM1704-K – SM5847AF Philips CDM-4
SHERWOOD CDP301R TDA1541 – SAA7220P/A CDM-4/31
SHERWOOD CDP311R TDA1541 – SAA7220P/A CDM-4/31
STUDER CD221 2 x SAA7321GP / SAA7323GP CDM-1/MKII / CDM-4/27 / CDM-4/19
STUDER D730 TDA1547 (DAC7) – SM5803APT CDM-4/36 Pro Metallic
STUDER D731 TDA1547 (DAC7) – SM5803APT CDM-4/36 Pro Metallic
STUDER D732 TDA1305T CDM-4 Pro
T+A CD1000 AC TDA1541 – SAA7220P/A CDM-2/29
TANDBERG TCP 3015A 2 x TDA1540 – SAA7030, MAB8441P T018 CDM-2
TANDBERG TCP 3015A 16 bit TDA1541 – SAA7220, MAB8441P T018 CDM-2
C) MCU IC's in CD player models with all versions of CDM-2, CDM-4 and CDM-9 (>TDA1540) (Technics TEC Toshiba Philco and Philips only)
All Technics models with CDM-4 from Philips: all IC's (even MCU parts) from Matsushita (MN series)
TECHNICS SL-P202A MN6471 – MN6625 CDM-4/19
TECHNICS SL-P212A MN6471 CDM-4/19
TECHNICS SL-P272A MN6474 CDM-4/19
TECHNICS SL-P277A MN6474 – MN6625 CDM-4/19
TECHNICS SL-P377A MN6474 – MN6625 CDM-4/19
TECHNICS SL-P477A MN6474 – MN6625 CDM-4/19
TECHNICS SL-PG200A MN6474 CDM-4/19
TECHNICS SL-PG320A MN6475 CDM-4/19
TECHNICS SL-PG340A MN6475A CDM-4/19
TECHNICS SL-PG400A MN6474 CDM-4/19
TECHNICS SL-PG420A MN6475A CDM-4/19
TECHNICS SL-PG440A MN6474 CDM-4/19
TECHNICS SL-PG500AMN6474 CDM-4/19
TECHNICS SL-PG520A MN6474 – MN6626 CDM-4/19
TECHNICS SL-PG540A MN6474E – MN6626 CDM-4/19
TECHNICS SL-PJ28A MN6477 CDM-4/19
TECHNICS SL-PJ37A It's a Transport CDM-4/19
TECHNICS SL-PJ38A It's a Transport CDM-4/19
TECHNICS SL-PS620A MN6474 – MN6626 CDM-4/19
TECHNICS SL-PS740A MN6474E – MN6626 CDM-4/19
TEC 2910 CD TDA1541 – SAA7210P CDM-2/10
TESLA MC 911 TDA1541A – SAA7220P/B CDM-4/25
TESLA MC 902 TDA1541 – SAA7220P/A MAB8441P T082, CDM-2/29
TOSHIBA XR-9118 TDA1541A – SAA7220, XC86606P CDM-4/11
TOSHIBA XR-9128 TDA1541A – SAA7220P/B XC86606P CDM-4/11 / CDM-4/19
TOSHIBA XR-9318 TDA1543 CDM-4/19, XC99659P
TOSHIBA XR-9328 TDA1543 CDM-4/19
XTC CDT-1 'LE' It's a Transport – SAA7210P CDM-4
PHILCO CD2471 TDA1541-R1 – SAA7220P/A ZC93486P CDM-2 / CDM-4/11
Philips CD10-50-60-85-351-372-373-450-470-492-500-502-560
PHILCO CD2471 TDA1541-R1 – SAA7220P/A CDM-2 / CDM-4/11
PHILIPS AK 601 TDA1543A – M50423FP MAB8441P T016, CDM-4/19
PHILIPS AK 603 TDA1543A – M50423FP CDM-4/19
PHILIPS AK 630 SAA7341GP S9306 COP888EG DDU/N (National Semiconductor) UM6264BM-10L, CDM-4/19
https://gyulaboncasztala.blog.hu/2020/12/27/philips_ak630#gallery-1609092678_16
PHILIPS AK 640 SAA7341GP S9352 COP888EG DDU/N (National Semiconductor) CDM-4/19
PHILIPS CD-50 TDA1541A – SAA7220P/B CDM-4/19 Composite
PHILIPS CD-60 TDA1541A – SAA7220P/B CDM-4/19 Composite
PHILIPS LHH300 2 x SAA7321GP – SAA7220P/B CDM-4/36 Metallic
PHILIPS LHH500 2 x SAA7321GP – SAA7220P/B CDM-4/36 Metallic
PHILIPS LHH500R 1 x TDA1547 – SAA7350AGP – SM5803AP CDM-4/36 Metallic
PHILIPS LHH600B 2 x TDA1547 – SAA7350GP – SM5803APT CDM-4/36 Metallic
PHILIPS LHH700 2 x TDA1547 – SAA7350GP – SM5803APT CDM-4/36 Metallic
PHILIPS LHH800R 1 x TDA1547 – SAA7350GP – SM5803APT CDM-4/36 Metallic
PHILIPS LHH900R 1 x TDA1547 (DAC7) CDM-4/36 Metallic
PHILIPS CD-85M TDA1541
PHILIPS CD-94M TDA1541
PHILIPS CD-100 TDA1540
PHILIPS CD-101 TDA1540
PHILIPS CD-104 TDA1540 MAB 8440P D041
Philips CD110 M50423FP MC68HC05C8P/9411 CDM4/19 TDA1543
Philips CD115 M50423FP MC68HC05C8/ZC99892P/ZC99944P TDA1543 TMP47C212, CDM4/19
Philips CD130 M50423FP MC68HC05C8P/9411/ZC99745P (?) TDA1543 CDM4/19
Philips CD140 M50423FP MC68HC05C8P/9411/ZC99944P (?) TDA1543 CDM4/19
PHILIPS CD-150 TDA1540 OKI M2128-15, 5Z054Y (RAM.), MAB8441P-T014 u. MC6805L3P (Display-Proc.)
Philips CD-160 MAB8441P T012 o. T082 (Servo-Proc.) MAB8441P T065 o. MC6805L3P o. XC89507P (Display Proc) MSM4202A Display
Philips CD-160 MAB8441P-T082 SAA7220P/A (DF) TDA1541 (DAC) XC89507P CDM-2 SAA7220P/A (DF) TDA1541 (DAC) CDM-2/10
Philips CD162-CD164-AK630: SAA7341GP cdm4/19 COP888EG-WBS
PHILIPS CD-200 TDA1540
PHILIPS CD-202 TDA1540
PHILIPS CD-204 TDA1540 MAB 8440P D041
Philips CD-207 TDA1541 – SAA7220P/A – TDA1542 CDM-2-P MAB8441 T082
PHILIPS CD-210 TDA1543 MC68HO05C8 PCF8576
Philips CD230: TDA1543A – M50423FP CDM-4/19 XC409026P
Philips CD320 XC400005P XC400008P TDA1543A CDM-4/19
Philips CD340 SAA7341GP CDM-4/19
PHILIPS CD-350 2x TDA1540 MAB8441P-T012 (Servo CDM-2), MAB8441P-T014/MC6805L3 (Display-Proz.,Circuit A/B)
PHILIPS CD-360 2x TDA1541 MAB8421P-F037, MAB8441P T012 (CDM2/10), MAB8441P-T078 CDM2/29), MAB8461P-W042 (Display-Proc.)
Philips CD371 SC93416P
PHILIPS CD-380 TDA1543 MC68HC05C8/XC99659P
PHILIPS CD-465 TDA1541
PHILIPS CD-460 TDA1541 MAB8441P T012 (Servo CDM2/10) MAB8441P T078 (Servo CDM-4/25) MAB8441P T065/MC6805L3P/ZC89505 (Display)
PHILIPS CD-471 TDA1541 SAA7210P MC68HC05C4/ZC93486P CDM-2
PHILIPS CD-472 TDA1541 MC68HC05C4/SC93486 (Servoprocessor)
PHILIPS CD-473 TDA1541 MAB8441P-T120/MC6805L8/ZC86609 (Servo-Proc.) TMS6763 (Display-Proz.) MAB8441P-T146 (?)
Philips CD-480 X/S/ZC99559P
PHILIPS CD-480 TDA1543 XC99659P
PHILIPS CD-482 TDA1543
Philips CD-555 Sound-System MAB8441P-T012 (Servo-Proc.)
http://stereo2go.com/forums/threads/resurrection-of-a-philips-cd555-sound-machine.791/
PHILIPS CD-582 TDA1541 XC99659P
PHILIPS CD-584 TDA1541 XC99659P
PHILIPS CD-600 TDA1543 U3090MG MC68HC05C8P/ZC99684
PHILIPS CD-604 TDA1543 MC68HC05C8P/9441/XC409026P U3090MG
PHILIPS CD-605/615 SAA7310GP/SAA7321GP MC68HC05C8P/ZC99698P U3090MG TDA1543
PHILIPS CD-608/618 SAA7310GP/SAA7321GP MC68HC05D9P/ZC400009 U3090MG PCF3523P (S/P-DIF Transmitter)
PHILIPS CD-610 TDA1543 ZC99698P
PHILIPS CD-614 TDA1543 MC68HC05C8P/9441 U3090MG
PHILIPS CD-620 TDA1541 MC68HC05C9P or SC409009 TMS3763 (Marantz 74CD50/CD60)
PHILIPS CD-624 SAA7323 ZC400005P
PHILIPS CD-630 TDA1541 MC68HC05C8P 47C670N
PHILIPS CD-634 SAA7321 ZC99702P
PHILIPS CD-640 TDA1541 MAB8441P T082, MAB8461P W056, MAB8421P F046
PHILIPS CD-650 TDA1541 MAB8441P T012 (T082), Servo MAB8461P W079 (Display+Contr), MAB8421P F050 (Fav Track selection)
PHILIPS CD-670/660 TDA1541 MAB8441P T082, MAB8461P W079 (Display+Contr), MAB8421P F046 (Fav Track selection)
Philips CD-680 MAB8441P T146 XC86604P/XC86615P TDA1541A – SAA7220P/B CDM-2/10 / CDM-4/11
Philips CD-760: M4804A (SAA7210P) MAB8441P T082, MAB8461P W079, MAB8421 F046, M4812A (SAA7220P) TDA1541 CDM2/10
https://www.bramjacobse.nl/wordpress/?p=1805
PHILIPS CD-782 TDA1541 MAB8441P T113 / MAB8441P T120 MC6805L8/XC86608P TDA1541 – SAA7220P/A CDM-4/11
PHILIPS CD-820 TDA1541A
PHILIPS CD-824 TDA1541A SAA7321GP, SAA7310GP, ZC400005P, X24C16P, MN4264P PCF3523P (SPDIF-Transmitter)
PHILIPS CD-830 TDA1541A – SAA7220P/B ZC99702P CDM-4/19 Composite
PHILIPS CD-834 SAA7321GP ZC99798P CDM-4/19
PHILIPS CD-840 2 x SAA7321GP – SAA7220P/B ZC99697P PCB83C654 P006 (INTEL) CDM-4/19
PHILIPS CD-850 TDA1541 ZC99702P
PHILIPS CD-850 MK-II TDA1541 Philips PCB83C854 P003 (INTEL)
PHILIPS CD-930 SAA7350 ZC405027P (Servo) ZC410915P (User Processor)
PHILIPS CD-931 SAA7350
PHILIPS CD-940 SAA7350S ZC405027P (Servo) ZC410915P (User Processor)
PHILIPS CD-950 TDA1547 ZC405027P (Servo) ZC400022P (User Processor)
PHILIPS CD-951 TDA1547 MC68HC05C8 MC68H05D9
Philips CD1202 MAB8440PB
Philips CDB473 MAB 8441P T113 28pin, X2816BP 24 pin
D) MCU IC's in CD player models with CDM-0/CDM-1/CDM-2/CDM-4 (TDA1540 only)
ARISTONA CD1104 2 x TDA1540P – SAA7030 CDM-1
ARISTONA CD1204 2 x TDA1540P – SAA7030 CDM-1
ACOUSTIC RESEARCH CD-04 2 x TDA1540P – SAA7030 CDM-2
Bang & Olufsen Beogram CDX 2 x TDA1540P – SAA7030 CDM-1
CAMBRIDGE AUDIO CD1 6 x TDA1540 / 3 x TDA1541 CDM-1
ERRES CD1104/CD1204 2 x TDA1540P – SAA7030 CDM-1
MAGNAVOX FD1040 2 x TDA1540P – SAA7030 CDM-1
MAGNAVOX FD2040 2 x TDA1540P – SAA7030 CDM-1
MAGNAVOX FD3040 2 x TDA1540 – SAA7030 CDM-1
MARANTZ CD-34 2 x TDA1540P – SAA7030 CDM-1
MARANTZ CD-44 2 x TDA1540 CDM-1
MARANTZ CD-54 2 x TDA1540 – SAA7030 CDM-1
MARANTZ CD-64 2 x TDA1540 – SAA7030 CDM-1
MARANTZ CD-74 2 x TDA1540 – SAA7030 CDM-1
MARANTZ CD-84 2 x TDA1540 – SAA7030 CDM-1
MCINTOSH MCD7000 2 x TDA1540 – SAA7030 CDM-1
MERIDIAN MCD 2 x TDA1540D – SAA7030 CDM-1
MERIDIAN MCD-Pro 2 x TDA1540D – SAA7030 CDM-1
MISSION DAD7000 2 x TDA1540 – SAA7030 CDM-1
PHILIPS CD101 2 x TDA1540D – SAA7030 CDM-1
PHILIPS CD104 2 x TDA1540P – SAA7030 CDM-1
Philips CD151/152 7030-2x1541-cdm2/10
PHILIPS CD204 2 x TDA1540P – SAA7030 CDM-1
PHILIPS CD-300 2x TDA1540 CDM-0
PHILIPS CD-303 2x TDA1540 XC89505P proz.) CDM-0
PHILIPS CD304 2 x TDA1540P – SAA7030 CDM-1
PHILIPS LHH2000 2 x TDA1540P – SAA7030 CDM-0 / CDM-1
PHONOPHONE DISCAMP 3 2 x TDA1540 CDM-1
PS AUDIO CD-1 2 x TDA1540P – SAA7030 CDM-1 / CDM-2
RADIOLA CD1104 2 x TDA1540P – SAA7030 CDM-1
RADIOLA CD1204 2 x TDA1540P – SAA7030 CDM-1
REVOX B 225 2 x TDA1540 – SAA7030 CDM-0 / CDM-1
AIWA DX-660 2 x TDA1540P – SAA7030 CDM-2/10
ARISTONA CD1151 2 x TDA1540P – SAA7030 CDM-2/10
California Audio Labs Tempest 2 x TDA1540 – SAA7030 CDM-2
Conrad-Johnson Sonographe SD-1 2 x TDA1540P – SAA7030 CDM-2
DIATONE DP-300P 2 x TDA1540P – SAA7030 CDM-2
DUX CD1005 2 x TDA1540P – SAA7030 CDM-2/10
ERRES CD1005 2 x TDA1540P – SAA7030 CDM-2/10
ESTONIA 001 2 x TDA1540P – SAA7030 CDM-2
GRUNDIG CD 35 2 x TDA1540P – SAA7030 CDM-2/10
MERIDIAN MCD-2 2 x TDA1540P – SAA7030 CDM-2/10
MERIDIAN 207 (14 Bit) 2 x TDA1540P CDM-2/10 / CDM-2/29
MAGNAVOX FD1041 2 x TDA1540P – SAA7030 CDM-2/10
MAGNAVOX FD1051 2 x TDA1540P – SAA7030 CDM-2/10
MAGNAVOX FD2041 2 x TDA1540P – SAA7030 CDM-2
MARANTZ CD-5L 1 x TDA1541 – SAA7220P/A CDM-2/10
MARANTZ CD-25 2 x TDA1540P – SAA7030 CDM-2/10 / CDM-2/29
MARANTZ CD-45 2 x TDA1540P – SAA7030 CDM-2/10 / CDM-2/29
PROTON 830R 2 x TDA1540P – SAA7030 CDM-2/10
RADIOLA CD1005 2 x TDA1540P – SAA7030 CDM-2/10
SAE D102 2 x TDA1540P – SAA7030 CDM-2/10
SCHNEIDER CD1005 2 x TDA1540P – SAA7030 CDM-2/10
SCHNEIDER CDP8001 2 x TDA1540P – SAA7030 CDM-2
SCHNEIDER CDP8050 2 x TDA1540P – SAA7030 CDM-2/10
SHERWOOD CDP300R 2 x TDA1540P – SAA7030 CDM-2
SHERWOOD CDP310R 2 x TDA1540P – SAA7030 CDM-2/10
SONAVOX C-100 2 x TDA1540P – SAA7030 CDM-2/10
TESLA MC 901 2 x TDA1540P – SAA7030 CDM-2/10
As to note in post #5, the firmware resp. program memory of the mentioned MAB8441P Txxx coding isn't only in use in a specific model (as usual in most cases). Thus I conclude, that also for the firmware actually must Philips release the associated information.
In the attachment are the associated images to post #5
  • MAB8441P-MAB8461P-MAB8421P Aug. 1990.pdf
