I have tryed but failed so thats why I ask all of you.
How to make my PC work as a music player so that I can switch between USB in from analog sources or toshlink and jRiver.
The PC out is connected to a Najda DSP prosessor with USB in.
I'm not the best person to help you, but can show you how my system is configured.
On the PC, I use Reaper (DAW) to select the source which it then routes through onboard Lynx card to external Apogee DAC.
I hope the attached diagram helps to explain further.
You got a nice speaker system.
Does the Audax PR 170 keep up with those horns in character and speed?
Greets, Klaus
Is the Nadja doing the DSP? How are you getting analog into the PC?
Yeas Najda is at the momen doing DSP. But only 1000 taps per channal. So seeking how to get all sources in to the PC and switch between them. Then it wold bee easy to convolate and use a 8 channal DAC.
Greets, Klaus
Hi Klaus, thanks, only my 2nd pair of speakers that I've built. Audax seems to keep up, but because the horns are better than Heco Direkt, hard to say. Original plan was to use jbl2482 but they became rare & expensive. Any alternative suggestions are welcome. Regard Barry
I was told to be careful with different digital clocks in various pieces of equipment. Hence Apogee is the master clock in my system. How about something like Xilica 4080 Xilica XP-4080 – Thomann UK
- PC Based
- PC win10 as preamp and convolution prosessor
