The one thing I hate about my antique scope is that its not portable.
I see these $100 and less handheld scopes on ebay. Are they worth it? I'd like to use it on tube and ss amps (so up to 550vdc).
Be careful with specs.
i.e. 100MHz scope is probably only good for a few MHz bandwidth despite them saying otherwise.
I develop very low frequency scopes and my 3.3mega sample/s is just about good for 100KHz sine wave truthfully.
Extrapolation of waveforms is cheating and doesnt take into account different possible waveforms. Some suggest 2 points for a sinewave ! I would suggest at least 30 or at least thatswhat I have found on mine.
It looks like the DSO150 is less than $30. I went ahead and took a gamble on it. It only takes up to 50vpp but I have a 1x/10x probe so I'll just have to be careful to switch it as needed and use a blocking cap when working with tubes. If I kill it, its only $30.
Also, frequency wise, in audio, I suppose I will likely only be able to use it for signal tracing and bias. Probably very limited for other purposes. Maybe useful for duty cycle and pwm but I won't use it as much for that.
I have the single channel version of this one (which is dual chan) : ??????????????????120M??500M??????-???
Works very well, within the limitations of the 'soft' controls.
I have been using the older DSO138. It does most of what I need for $25.
I have one of Nigel's USB scopes. It works OK. The software is bare bones and locks up now and then.
Sub $100 digital scopes may be okay for looking at audio frequencies. Likely not so good if looking for signs of small parasitic oscillations or some other problems. Also, sometimes 2 or more channels really are needed. The other thing is consider the sample rate of the device. How many samples per cycle do you want to see? More than 2 or 3? They don't have sophisticated trigger options to accurately capture repetitive waveforms up near the maximum sample rate.
IMO, the JYETech DSO-SHELL DSO150 is fine within it’s specified range (up to 200kHz and up to 50V with a x1 probe).
Original jyetech assembled dso-shell dso150 digital oscilloscope module 9v Sale - Banggood.com
I drove it from a signal source in parallel with a Rigol DS1202Z-E.
With sinusoidal input, waveform integrity is excellent up to 120kHz. It’s measurements are good up to 200kHz.
Square wave shows as square wave up to 80kHz
I had assembled it from a kit. I use it for many years now, it’s robust and reliable.
George
Excellent! Thanks for the input guys! Good chart comparing a real scope vs the DSO150. For my needs, I believe the toy scope will usually be enough that I won't bother with getting the real scope out of storage. I think I paid $100 each used for the two vintage o-scopes I have back around 2007. Amazing what you can get for $30 as tech has improved!
- Design & Build
- Equipment & Tools
- Sub $100 ebay handheld O-Scopes. Do they work?
