Hi guys, absolute amateur here.
I'm building my second boombox this lockdown and have struck a few problems.
I'm using a diy 10s 18650 36v battery which when fully charged reads 42 v (I did not realise this was the case. Thoight it was 36v and below)
The amplifier I have brought is a wondom amplifier rated at a maximum input voltage of 39 or minimum around 24v (36 is the ideal voltage).
Is there a way that I can reduce the output of the battery pack to 39v or less? So far I have been researching buck down converters but haven't found any that go above 40v .
Any ideas are welcome
Thanks in advance
Charlie
Thanks in advance
Charlie
A couple of diodes in series will each knock down the voltage ~0.65V
Be extremely careful with 18650's. Careful in storage, handling and application. They can kill you.
Something like this ?Hi guys, absolute amateur here.
Thanks in advance
Charlie
DC Buck Converter, DROK DC to DC Step Down Power Supply Module 10V-65V to 0-60V | eBay
