Restoring a General Radio 107N variable inductor
I recently acquired a General Radio 107N variable inductor. The front panel was in good shape but the enclosure, made of solid walnut boards, had a lot of damage to the finish. My goal is to clean the front panel, clean and lubricate the main and vernier dials and restore the enclosure as period-correctly as possible.
Looking at old GenRad catalogs, they refer to the finish as “polished walnut”. After a bit of online research and my own examination of the enclosure itself, I have concluded that that original finishing schedule was an application of sanding sealer (shellac), followed by grain filler, another coat of sealer (shellac), then top-coated with lacquer. Lacquer at the time was either nitrocellulose or phenolic. Close examination of lacquer flakes from off the cabinet look lighter then phenolic; my educated guess is that it is nitrocellulose that has darkened over the decades.
I was originally going to strip the finish using Formby’s furniture refinisher. Unfortunately, my container of refinisher got contaminated and in the interim my fair state has outlawed the stuff.
So I began by hand sanding with 150 grit sandpaper. Progress will be photographed. Pictured below is the finish next to sanded bare for contrast.
Hi Brinkman
I wish you have a good time restoring the housing of this beautiful instrument. It worths it.
Mine (107M) is true to dial’s indications. I haven’t tested for self resonance.
George
Reactions: Brinkman
Progress
I have sanded all sides to 220 grit. Weather permitting, tomorrow I will remove the enclosure from the body and begin sealing with shellac and with luck, begin filling the grain.
In the shop over the years, I've restored several "antique" radios for customers.
Ranging from a floor console RCA "Radiola", a 1920's Emerson console, Atwater kent sets, and those "coffin box" multi-dial table sets.
A coffin box 3-knob set came in once from as guy, I think it had 5 tubes inside.
The customer complained after he took it home, that he couldn't tune in AM broadcast except for only one station (1600Khz).
I told him that his radio, numerous times, was designed for the old radio band, starting around 1600 Khz and up.
Enclosure after a coat of dewaxed shellac (left) and then after one application of grain filler (right).
