Full bridge using 2 dual anode rectifiers
Hi Guys,
was wondering , as I see some implementations of the full bridge rectification using soft recovery dual rectifiers with common cathode like the famous MUR3020 ...
I'm struggling to understand how that is possible when in full bridge implementation there would need to be both common cathode and common anode version of the rectifier.
would be great to have the schematics as well to understand it better.
thanks,
Efi
You can use a dual rectifier as a single rectifier. Two of the same model plus a CT winding makes a full-wave rectifier. With less voltage loss than a FWB.
The question did not sound to me like someone would ask about full bridge rectification in a hf switcher. When someone talks about "famous" diodes it sounds to me more like a question from a audiophile, normal grid 50/60Hz transformers, "fast" diodes made famous by some guru. I may be wrong off course.
Anyway, that is why I wanted to him, and others like him, make clear that there is no free lunch.
For PRR and many others this is nothing new, but for people not knowing this:
Secondary winding losses are considerably lower if, instead of using 2 serial connected windings (that are idle at least half of the time) you put the same amount of copper working twice as long by feeding a full bridge.
