Hi !
I used 2 methods :
Option 1:
If you only need to make your PCB green (or any color), you can try acrylic inks used to paint on glass.
The one I found needs to be cured by heating it in the oven and is manufactured by PEBEO. It can be found at Mal-Wart.
(Make sure that the one you try isn't electrically conductive). When applied with foam applicator, it gives pretty nice results.
Option 2:
If you need a real solder mask, you'll need to deal with serigraphy stuff. You can find photo-serigraphy starter kit here by example: http://www.dharmatrading.com/html/eng/1940565-AA.shtml
The process involves a lot of time in silkscreen preparation and is not really recommended for single parts. The process becomes interesting in large scale production.
For me, the most complicated part was to find inks and solder paste. I used to order "samples" from PCB manufacturing plants. 500ml will last forever.
I hope this helps !
I used 2 methods :
Option 1:
Option 2:
I hope this helps !
OH, I forgot to mention :
If you go for option #1, you can cover your soldering pads with clear sticky film used to protect books and shelves. When curing the ink in the oven, the plastic film will shrink and/or burn. When soldering, the use of "flux" allows a clean job.
Elkaid,
Is this the pebeo stuff that you use?
http://www.theartshop.com.au/category497_1.htm
Also, I assume you are using FR-4 type PC boards and they withstand this heat without problems? Do you put it into the oven for the recommended time and temperature?
Thanks.
Thanks.
I took contact to the Danish importer of Pebeo, I got adviced to try Vitrea 160.
I will make a few experiments with that in the nearest future an make a report.
Magura 🙂
Magura 🙂
If you are going to use the Pebeo Vitrea paint, you will need to ensure that the PCB you are going to use can support the temperatures required to set the paint (160°C).
I've done a search and for FR-4 PCB's, the glass transition temperature can range from 120°C to 180°C.
Does anyone have a source of high temp FR-4 PCB's? (Other than going to FR-5).
Hi guys,
Sorry for the delay !
Hmmm, the link wasn't working this morning. However, I'm using PEBEO Vitrea paint.
By personal experience, you don't absolutely need to heat the PCB to 160°C for the suggested period of time. It gave me good results when heating the PCB until the paint is doesn't transfer on your finger when touching it. Then, I simply lay the PCB at room temperature.
However, I'm really looking forward to hear about your experience with Vitrea paint.
Have a nice day
Have a nice day
I just got my hands on some of that vitrea stuff, it seems to be available just about everywhere. I found it in a small hobby and crafts shop in a small town 😎
I'll see if I can find some time for playing around with it during the weekend.
Magura🙂
Magura🙂
Elkaid said:Hi guys,
Have a nice day
Thanks for the reply Elkaid.
In terms of baking the PCB, roughly what temperature and time do you use?
I've got three different colours on order and should receive them this coming week sometime, so I'm going to give them a try then.
Ok, here we go:
I had no problems, it works well. It needs a fairly thick layer, like 0.1mm.
I baked the PCB's at 150C for 45minutes, no problems here neither.
I tested if the PCB had been damaged by soldering a vire to a couple of pads and tried to pull the pads off the board, that was not possible.
So the conclusion is that Vitrea 160 works quite well for soldermask.
I plan to apply the soldermask with an airbrush, but the test was made by applying with a brush.
Magura 🙂
Magura 🙂
Magura, thanks for testing that out. I look forward to trying it for myself now.
BTW, did you try Elkaids method of putting clear stickers on the pads that you didn't want solder masked or did you just avoid those areas with the brush?
I'm glad it worked well for you too.
The airbrush method will probably give a much better result.
Using clear stickers works but I'd like to find another method which involves less time.
Have a nice day !
Have a nice day !
Something I haved seen done, but not done myself is to use a spray on conformal coating. Works on single sided boards *after* the components are sodered in place. It's not a true soder mask, but serves the purpose of covering the traces with a dialectric material.
Elkaid said:Hi,
Have a nice day !
I cut masking for the pads of 3mm rubber sheet and sparyed them with 3M medium bond sparay glue, all you gotta do then is to put them onthe pads, and they are easily removable. The rubber pads can even be re-used.
Magura🙂
have anyone tried flameproof solvent resistant spray paints which are usually used on engines?
and how about the coatings on the magnet wire? i think its polyurethane. while soldering a magnet wire, i noticed its coating was never burned and i've washed it with lacquer thinner to remove the rosin. it successfully resist the solder and solvent.
You will not be able to get that stuff as a private person,unless you have different laws according to such substances in the US. I use it for inductors so I had to buy 25kg of it, but I would not even consider to use it for soldermask for the simple reason that it is tremendeously toxic, so I try to avoid it as much as possible
The Vitrea 160 is fairly non toxic and works a charm, I see no reason to use polyurethane, even if it wasn't toxic, as it is not easy to deal with. The Vitrea can be applied with an airbrush, I consider that a major benefit.
Magura 🙂
has anyone tried assembling a board coated with Vitrea 160? Does the paint burn away, or work like a real solder mask?
Magura said:Ok, here we go:
Magura 🙂
bigmike216 said:has anyone tried assembling a board coated with Vitrea 160? Does the paint burn away, or work like a real solder mask?
Yes 😉
Magura 🙂
- Design & Build
- Parts
- DIY solder mask
