Stabilovolt regulators?
Anyone have any experience with the interesting Stabilovolt voltage reg tubes? I think they were not allowed to be exported to the USA (it's an excellent German product) which may explain why I very seldom hear about them. ?
I see them on ebay for not so much, and they certainly look very interesting for getting several voltages out of a single bulb. I think the most common had 70V outputs, and several in series, so 70, 140, 210, and 280V outputs.
They are relatively large, but the neon ? makes for cool display.
I once asked the same about spark gaps, and neons.
But that's a big neon!
Are neons noisy?
The flicker with AC (arc extinguishing around each zero crossing) and the large ignition vs holding voltage, would put me off trying them to for say...screen regulation.
Are neons noisy?
There was a thread on the power supply forum about low noise regulators and I believe it was the 85a2 tube that was mentioned. The noise figure was incredibly low for the given output voltage. My latest amp uses an 0a2 regulator for the screen grids and the voltage doesn't drift even out to three decimal points.
Besides having an ignition voltage that is greater than the maintaining voltage, glow discharge tubes also have an ignition delay that depends on how much radioactive primer is used and/or on the amount of light shining on it. It can be many seconds for a tube without radioactive primer used in darkness.
That's it. Btw, not any object can be accused of it's own of having been part of that Nazi evil, imho. It were those henchman who made them work in their cruel manner. For instance, would anyone of us refuse to use Telefunken LS 50 tubes (if one would get his hands on them...) 'cause they were implemented in the V1 flying »doodlebug« bombs?
Best regards!
... For instance, would anyone of us refuse to use Telefunken LS 50 tubes (if one would get his hands on them...) 'cause they were implemented in the V1 flying »doodlebug« bombs?
Best regards!
Hehe, you mean like this? Perhaps have the LS50 drive my Federal F-123-A, a 6G6G as input tube, and my Cossor or Mullard rectifier in the b+... Those are some of my WW2 era tubes.
Edit: Almost forgot, must have a Stabilovolt regulating in there as well.
Best regards!
Interesting. Do you have a link for the V1 design ?
Hello,
After WW2 the USA decided to '' hire '' Wernher von Braun who was a key figure in rocket science in Nazi-Germany. He made some serious contributions to those intercontinental ballistic missiles.
The USA kept VERY large stock of vacuum tubes whichs end up at auctions decades later where i would get them for 2$ a piece. At least they end up being used now.
I wouldnt mind tubes with a swastika. BUT i heard sometimes they were made by prisoners who would try to make them in such a way they would have a limited life time. Almost similar to your 1000$ plus smartphones, cheap labour, high price but limited lifetime.
Greetings, Eduard
The story goes that some people at Philips in Eindhoven deliberately put small amounts of chlorine in valves meant for the German army, not enough to cause immediate failure, but just enough to cause a short lifetime.
As an aside, a fence in the oval room of Teylers Museum in Haarlem is full of swastikas, but it was made long before Hitler was born, when swastikas were just a pretty pattern: Gebouw en geschiedenis — Teylers Museum
