Are the 47n60c3 MOSFETS good for audio?
-Hello, this is my first post here and i hope you guys can help me out. I recycled a pair of 47n60c3 mosfets from an old board and i wanna know if they are suitable to build an amplifier with, im thinking something like a simple class A amp using each transistor for each channel, so i want to know if these mosfets can be used for this kind of purpose 🙁
j1169-transistor-47n60c3-mosfet-to-247-rpi-D_NQ_NP_940361-MLV42378450883_062020-F.jpg
-I'll appreciate any help. Thanks in advance.
What I can say its got good avalanche characteristics , in other words if the Vdss is exceeded (rated voltage ) it wont break down if the drain current is within limits .
Will it work in class A --well yes .
Is it "as good " as a mosfet known to work well or designed for audio --er no.
But don't let that stop you as that TV forging program says ---"it will cut/kill "
Hi, there! Any update? I also bumped in a batch of these. Tnx.
180W is very ambitious, the datasheet does not describe low frequency SOAR, always an issue with modern MOSFETS. The shortest graph tp is just 1 ms. Real loudspeaker loads have low impedance and wild phase around port resonance, where music power content can be high
Without an SOAR graph its pretty foolhardy to try and use a switching MOSFET for analog duty, but this one has a graph and it suggests 7A @ 70V is on the DC limit which is pretty good. 0.18 C/W thermal resistance in total by my calcs.
The high voltage rating means the threshold voltage is quite high, losing more output swing than some MOSFETs.
