I recently completed a tube line preamp kit which takes eight 12AY7/6072A tubes. With NOS tubes approaching $300/ea I thought I'd compare the various models available from new manufacturers
There are gold plated and regular 12AY7s/6072As available from JJ. Electro-harmonics and others probably do too.
Any recommendations?
Thanks!
Thanks!
Wow.... 300 for one of those NOS tubes now?
Insanity!
I must be sitting on a Gold mine then, because I've got loads of spare RCA, GE, 12AY7's in my stock. 😀
They make great preamps and phase splitters driving 6BQ5's and such.
Insanity!
Deal?
What kind of a deal would you be willing to put together for me - a brother in tube usage, enjoyment and now need ?? 😱😱😉😉
A line stage with 8 tubes. Why so many?
jeff
Ah, sorry, those tubes are saved for my various amps in case I ever need them.
jeff
Indeed!
And which each tube is TWO triodes, one has to wonder....
I have supplied a number of JJ 12ay7 to microphone use, with zero complains.I recently completed a tube line preamp kit which takes eight 12AY7/6072A tubes. With NOS tubes approaching $300/ea I thought I'd compare the various models available from new manufacturers
Thanks!
I know that eurotubes.com ( no affiliation) has them in US .
Eurotubes.com in Milwaukee Oregon sells JJ 12AY7 tubes.
They get their tubes direct from JJ in Slovakia.
Then, Eurotubes re-tests them, including noise tests.
The JJ 12AY7 have spiral filaments.
I use the JJ 12AY7 tubes as the input tube in some of my amplifiers.
They work very well in that application.
I drive right over to Eurotubes.com to pick up my JJ tubes.
But I do not have a tube phono preamp.
All my former tube phono preamps used 12AX7 tubes.
- Tubes / Valves
- Best New Manufacture 12AY7/6072A Tube
