Power supply for car amplifiers ( smps)
Hi guys
My English is not good hope you will understand
I want to build a smps for car amplifiers ..i've seen many circuit .. there are simple smps that dont use any ic only transistors ie S9014 and a pair of mosfet and that is a simple one but i dont know its maximum power i will attach some diagram then any one with idea that how much power i can get from that.
Second
I've seen some diagram with even 4 mosfet...is the number of mosfet define how much power you can get ?
There is a simple diagram but with only 180w capacity it use two MOSFET...can i add mosfet in parralel to double the power ...because there is the diagram that use 4 MOSFET with 350w capacity
The self-oscillating circuit isn't practical for high power. You will have huge copper losses with that many turns. Most amps use 4+4 on the primary.
If you're going to buy a core instead of salvaging one, make sure that you use the right type of core. Inductor cores are different from transformer cores. I typically used P-material cores. F-material is another option. Some of the forum members with design experience may be able to offer other suggestions.
Magnetics - F Material
Magnetics - P Material
CWS Bytemark has cores:
Ferrite Toroidal Cores : Coil Winding Specialist, Inc.
