6N3/6N6 headphone amp using PCB.
That got to be for 2 channels..
Yes it is.
Hi kodabmx, I went through the stash of the tubes I have, and I see a lot of 6N6P and 6N2P. Can I use 6N2P instead of 6N3P? Are they considered equivalent? If yes, I would be interested in the board. Thanks
They are not equivalent nor are they the same pinout. 6N3P mu=~33, 6N2P mu=~100.
You can however use these adaptors: 1pc Gold plated ECC88 6922 6DJ8 6N11 6N6P TO 6N3 5670 tube adapter for you amp | eBay
and change the associated cathode resistors from 240R to 1k and it will work albeit with 3 times the gain.
I've made a revision to the board - the cap footprints are all onboard now.
No.
You chose the size based on the load you will drive and the LF response you want.
If you use it as a line stage, it could be as small as 1uF if you're using it to drive a tube amp.
I chose 470uF because they are common and give a good LF response on 32R headphones. If I was making one for just my ATH-R70x (470R) I'd use a 47u film cap only.
Koda
I am building an amp based on your schema,but I have some projekts before,so it doesnt go so fast...
attachment.php
