Nirvana SMPS to unearthed wall outlet
Maybe this has been asked before, but I can't find any anwers.
Will powering the Nirvana SMPS from an unearthed wall outlet negatively impact its AC EMI filtering capacities?
That's a bummer. Does this also apply to the Shanti PSU?Yes it will negatively impact . Everything is designed to be earthed.
No it does not apply to Shanti (or rather it does to a much lower level). Its better to have earth
Thanks! I guess that I'll need to upgrade the wiring and wall outlet...
Sorry to hear that , its very rare that there is no earth on power. Cabling its either very old or not done to spec.
Nirvana Shanti maybe less important but PE its also for safety.
Old cabling indeed. Before the nineties unearthed wall outlets were allowed in The Netherlands.Sorry to hear that , its very rare that there is no earth on power. Cabling its either very old or not done to spec.
Any update on Boss2 or Amp?
Will you be considering GaN FETs for a future amp or smps?
Boss2 , should be in stock in 10 days or less.
AMP is delayed , we expect the new PCB at end of Jan. 24H after I will post the new test data.
Sorry , busy here
I hope to release Boss2 betwen 1-3 Feb ( early next week)
The PCB house delayed our new samples for AMP and now its holidays , they told us "sometime in Feb".
Some bad news .
Boss2 in testing , shows a interference on IR when wifi is enabled . In about 15% of units , the interference creates problems . We changed the IR to a fully shielded unit and problem was solved. We hope to have stock by Friday.
More bad news. AMP PCB will be sent on March 5. Meanwhile we are working on the alu box and new LLC PCB.
Some bad news .
You caught the problem before release and have a solution, thats a real plus. Have you sent one to ASR/amirm for review?
I am more interested in the mono blocks at the moment, and I'm sure you can produce an excellent implementation of the TPA3255, and I will be waiting for those.
Mode delay on Boss2 , we worked this weekend for manuals and more. It will be released this week but I will take the time and make sure everything is fine.
Shanti 2...yes I am working on it. More power 3A and 3.5A , better cables ,same noise . More expensive.
TPA3255 , I am very confident on the new PCB (and its even slightly better than old one it will be final). I am not talking about THD but rather hi frequency noise . Team is already working on alu box.
First sample will be sent to Daniel(tpa3255 thread) , he has a lot of experience with class D , to ***** the SQ.
Awesome! Hope you think to link also here for those not following tpa3255 thread 😀
Can we try not to be "More expensive" by getting rid of the second output and further optimizing the first 3A output? Many users of Shanti are ending up just using the 3A output anyway (and some claim sounds better than the 1A output).
In addition, instead of increasing cost by providing "better cables," how about just placing a decent DC connector on the box? Many audiofools would want to use their own PlatinuDiamond cables anyway. 😀
100% agree with the sentiment on replacing the wire with a high quality DC barrel by Switchcraft or so!
Though, I think the 2x outputs is a selling point because a lot of Allo products will need 2x 5v supplies to be useful:
Rpi/USBridge + Revolution
Rpi/USBridge + Isolator for Boss
Rpi/USBridge + DigiOne Sig
etc.
If possible, can there be a coherent design approach to the chassis design, @cdsgames?
Perhaps the inlet and cables/jacks for Shanti are at the rear
Perhaps the USBridge Sig and Revolution use the same box
Perhaps the Shanti box is 2x the width of the other two, so you can stack elegantly
The current designs are disjointed, so I hesitate to put them on a rack, exposed. You may even hit a better pricing tier if you choose a common size!
etc.
- Vendor's Bazaar
- Shanti Dual LPS 5V/3A , 5V/1.5A
