Here is a link to a similar one. Same case, slightly different build:
Pass Labs Zen Amplifier - Price Reduced For Sale - US Audio Mart
150$ is less than all components with the chassis price.
Give to chokes some physical distance from psu transformer.
Chokes on toroids not the best solution imho..easy to modify.
Probably one Mr. Pass made from short series of 25 pcs. Zen's you can read in article " Return of Zen "
https://firstwatt.com/pdf/art_zen_redux.pdf extract:
" TM. Since writing the article I have had an opportunity?to build another 25 copies of the amplifier,
listen to it on a larger variety of loudspeakers, absorb criticism from the readership, and generally meditate on the project. "
The original Zen amp needed a quiet power supply or there was buzz. I ended up with a regulated supply. CLC was another option but not quiet enough for my speakers at the time.
Here are pics for ZM.
It has collected some dust.....can it still play?
Yes it still works, but things have advanced quite a bit and with just a few more parts things get much better, thinking ACA
and in case of confirmation that it actually is made with Papa's hands, it can be priceless
And that is the issue. If it was just someone's build, I'll pass on it (see what I did there?), but if it was Papa's build, I'd skip work and go get it.
- Help With Provenance: Pass Labs Zen
