Retro - A fully symetrical phono stage with RIAA filter
I built one, but need help with gain calculation
With my main phono stage in repair, I quickly whipped up a Retro to tie me over in the meantime.
I took the Edison approach and settled on the following resistor values:
R18 & R19 = 100R
R2=249R
R13=121R
With my Denon Dl-103R (it's out-of-spec w/ unusually high output @0.4mV) I get ~3,000x gain (@69.8dB and ~1.3mV) and with my Audio Technica OC9ML/II, I get ~2,850x gain (@69db and ~1.0mV).
I must say the unit sounds very good with mostly stock parts and low noise level, although I miss my tubed unit.
As I mentioned above, I took the Edison approach. But there's gotta be a mathematical method to derive gain -- Brian, or anyone, please help!
Hello,
I built a Retro Hi Z version and would like to know how to increase the output gain. My cart is Ortofon 2M bronze which produces much lesser volume compared to when connected using the phono input of the pre-amplifier. Should I also change the 22pf capacitor to match 150 - 200pf load capacitance of the cart?
I am using a 5 volt regulated wall wart. No problems.
IIRC, my Retro measured around 35 mA going into the BPBP. Current usage varies with the input impedance of your preamp. I don’t recall the exact input impedance of the BPBP but it is on the high side. I’m thinking around 100k.
I had ordered the Retro kit some time ago and finally finished my build yesterday. It really sounds amazing and the kit was so nice arranged, with every part marked and separated per channel. A huge thanks to Twisted Pear Audio for that!
I have a small issue, what is not related to the Retro, but my record player. It happens only to my diy phono pres. Hum! I have my rega Planar 10 modified with separately wired ground. It is located approximately 30cm away from mains equipment. If I move it further away, the hum (it sounds like ac transformer noise) gets attenuated. With the pres I did buy ( SPL Phonos, EAT eglo perit) there is no hum at all. What do manufacturers implement, to make their units immune to hum?
I do at least think, the tonearm wires or the arm itself is picking that up link an antenna. I also tried the cartridge floating and a wire from mains earth to ground, what did not help. Only if I unplug the player from the pre, the hum is gone.
Any clues are much appreciated. Moving everything further away from each other is not really an option, as my space is really limited. Maybe rewire the arm and use XLR plugs would also help?
Thanks!
Thanks again for your input. Based on suggestion, I did a little research, reading AES48 and "Pin 1 prroblem" bits. So I decided to connect pin 1 direct to the chassis near the input/output and made a star ground, where I tied all circuitry gnd to another place further away to the casing.
But the outcome is the same. Dead silent without the record player connected, and hum when the leads are plugged. I suspect the rega plugs and cable acting as a antenna.
So I will either relocate my stuff connected to mains supply, or rewire my tonearm to xlr, hoping the common shield will get rid of the hum.
