Looking for a Audio 5Kw AB class amp driver circuit
Suggest me how could I supply my +\- 60 VDC for preamp or amp.
So the supply is +/- 60Vdc?
That yields in theory to a maximum output of:
+/-60Vdc = 120Vtt
120Vtt = approx 40Vac (1/2√2*Vt)
(40)exp2 / 8Ω = 200W
Count the various losses, headroom and safety margins and we're talking 100W/8Ω...
When bridging you can multiply it by 4, but depends on the current reservoir of the supply.
Oh, 'music' power at 1 kHz in bridge is... 1800W (really, just math!)
+/-60Vdc = 120Vtt
Well said.
Could you send me any link to calculaye the whole system so far?
:xmas: Merry Christmas 6L6...
do we have a troll here?😱
A troll?........I think that if you are new to audio and the power numbers game played by manufacturers, you would soon realise that there is no real significance to the power ratings when we see 10,000W car audio amplifiers regularly promoted, even in the U.S.
It's amusing to learn what that number really signifies to people who buy the stuff but it's clear that all they really care about is bragging rights. The bigger the numbers, the better. Whether they are real numbers or impossible just doesn't matter when they are printed on the box for all to see
Take oldish DBTechnologies PA2.0 or 3.0 well known schematic and just build it.
But what's the goal?
Full-band amplifier asks for ugly passive XOing, so out of interest.
Active digital XOing allows you to divide power between drivers. Since lows and subs are really slow - the can be easily amplified by D-class while relatively fast highs (compression driver) doesn't need such a power.
Ok. You just put a point to start.
D class is my next plan. At this moment I want to build classAB and ClassH.
Now discuss your knowledge on "Lows" and " "High". How do you want to amplify any audio signal with a particular frequency and how could we make its quality better. Amplified sound need to be clear without any exta noise.
Yeap. Its should not be a troll!.
In a big place of gathering you may need it.
Interesting to see how could we manage this huge power. Technology behind it.
One technician said me Car battery charger or something is used to supply the amplifier power. 12 v DC can make 220V AC, I saw a circuit system using 2 multivibrator then current enhancing is take place.
With responses like these, I hear nothing but alarm bells ringing.
Sounds like Hasan has less than no idea what they want or actually need and is wanting to make a commercial product.
Hasan - How about you you tell us what your requirements are, what the end use is, and what your budget is.
Do you have any guideline to build a 500W system? Share your knowledge what you have done so far. Lets come to the point.
1. How do your supply DC voltage to your Amp?
2. Which topologies should I chose for cheap project and old type class AB.
3. How do you calculate /analysis your circuits in terms of gain, power.
There are no need to discuss my knowledge.
Take DBX Driverack 260 or Driverack PA2 or Behringer DCX2496 and crossover audiobands as you wish.
