Denon DRW-660
Hello. Having an issue with a Denon DRW-660 cassette tape deck.
This unit has two decks. Both decks play cassettes no issues. Both have a directional switch which changes the side being played and it operates no issues.
The problem is when engaging either fast forward or fast reverse, it starts to engage and then dis-engages and stops (both decks exhibit this trait). Any ideas? Does this unit have a auto shutdown if the amperage draw is too high for the motors or other similar built in function?
I've tried different cassettes and no changes in behavior. The issue is with the machine.
Thanks.
