Looking for a Audio 5Kw AB class amp driver circuit
5kW, seriously? This could be, for example; two amp’s in BTL mode with rails of +-140Vdc. When you would look at Safe Operation Area of the output devices, you will notice that you need probably around 20pairs per amp!
Of you want some quality, I don’t believe you can DIY this amp for less than €3000 (rough estimation). Of it is for PA, I suggest to get a class D.
Amp-230
Class AB, max +/-230V rails, max output 4.5kW @ 4 ohms load.
You can bridge this amp for more higher output.
Really well said. 5W is a big issue to handle with. Don't you think I need also speaker or mic protection. How about class H.
Suggest any solution then for 500W.
Take oldish DBTechnologies PA2.0 or 3.0 well known schematic and just build it.
But what's the goal?
Full-band amplifier asks for ugly passive XOing, so out of interest.
Active digital XOing allows you to divide power between drivers. Since lows and subs are really slow - the can be easily amplified by D-class while relatively fast highs (compression driver) doesn't need such a power.
Okay guys!
Lets start with 500W.
Suggest me how could I supply my +\- 60 VDC for preamp or amp.
Class D won't make money at this moment in this area.
Related technical notes, reference will appropriated.
How much does it costs?
Suggest any similar design circuit if its not open source.
With responses like these, I hear nothing but alarm bells ringing.
Sounds like Hasan has less than no idea what they want or actually need and is wanting to make a commercial product.
Hasan - How about you you tell us what your requirements are, what the end use is, and what your budget is.
Hi Audio exparts,
I am looking for a 5k audio amplifier in AB class mode operation. Kindly suggest me any any related design that might be cheap and reasonable.
Hasan
ask Mr. Nelson Pass.
A mingling or marriage of SuSy (X-series, bridge configuration) and STASIS (serial mode of output power devices for high voltage applications) maybe provides the wanted output power.
Reactions: vishal raju
