Amplifier Modules and PCBs For Sale
  • Thread starter Thread starter Deleted member 148505
  • Start date Start date
So if Silmic is too veiled and Muse too harsh, it will be interesting to taste the sound of the combination of (say) 10uF Silmic/Muse in parallel with 1uF Wima/Kemet/other foil cap under the PCB. Will try it after holidays.
ppppp: I started reading the alterations suggested by ClaudeG in the "Aiyima TPA3251 Modification Build Thread !" mainly Post#s 105, 143 & 144 where he suggests numerous by-passing implementations. I’m going to try a few of the ones suggested in Post 144 on Lester’s board. I’ve ordered the parts so we will see.
Regards, Pete
Lester : would it be safe to use 10uH + 0.68uF with the current PFFB in place?
Thanks,
Pete
I suggest use the stock 1uF per slaa788a, deviating from the default PFFB values and configuration has a large impact on stability.
Regards, Pete
Putting 100nF bypass caps under large electros was being frowned upon (I remember AndrewT) because of possible ringing.
Your advises and care are much appreciated Lester, thank you! Is 10uH + 1,22uF ok with my PFFB parts? 1,22uF gives me the best looking graphs and damping factor for my 4Ohm speakers. Changing zobel is not problem, if needed.
Farnell/Newark has lots of them stocked.
I will try different values next month after the Christmas/holiday rush 🙂
Thanks. Which is the header for FREQ_ADJ/GND/DVDD jumpers?
Solder jumper SLAVE_JMP will pull the FREQ_ADJ to DVDD. We don't need to change resistors etc.
Also PFFB config is dependent on osc frequency, so don't change resistor for FREQ_ADJ. If you will change the frequency, you have to change the feedback components or disable PFFB because the amp will go unstable if the FB config is incorrect.
On the TPA3255EVM, moving the jumper to select Slave Mode disconnects FREQ_ADJ from ground and pulls it to 3.3V (I assume that is DVDD):
https://www.ti.com/lit/df/slar129a/slar129a.pdf?ts=1608646859138
On yours, by connecting a solder jumper to pull FREQ_ADJ to DVDD, won't it connect DVDD to ground (through whatever resistor you have - 30kR on TPA3255EVM)? Is that OK? I mean, it's not really a short because of the resistor, but the TPA3255EVM doesn't have any connection to ground at all once the slave jumper is in.
EDIT: 0.11 mA, I guess that's nothing 🙂
commstech, ppppp, asuslover & Lester, just let you tell you where I am with Lester’s 3255 amp.
It sounds really good now, sort of a silkiness with no harshness and nice detail within the music. As a reference, I’m driving the amp using 3e-Audio’s 48V SMPS (no longer sold) with the stock 4 output caps changed to four Panasonic’s 1000uF 63V. SE signal input. A number of the by-pass ideas are coming from ClaudeG’s post #144 in the Aiyima tpa3251 Modification forum.
1) I by-passed the 1800uF Panasonic FC caps with 1uF WIMA MKS (waiting on a new order since I’d rather use at least 2.2-3 uF for by-passing; approx a 1:500-600 by-pass).
2) the pre-tap 3255 caps were changed to 2.2uF Nichicon UES bipolars
3) I tried two different pre-1656 caps; either WIMA 2.2uF MKS or the suggested KEMET SMR 1uF caps. I really liked the WIMAs but pulled them only because they sounded really shrill on bright violin passages. The KEMET SMR quieted down the music a bit but I liked the silky calmness they imposed and details are still quite present.
4) I mounted a Elna Silmic II (10uF 35V) under the board across pins 4&8 of the op-amp DIP mount.
I think Lester’s amp sounds really good now. I might try two other by-pass options on the 1656’s pins 4&8 once I get the parts. I think that’s all I have for now.
Regards, Merry Christmas all
Pete
wow Pete, i really look forward to your update.
Nice update Pete, thanks. I can't wait to jump in the game too, when I'll get all parts in january...
Just have question to you about pre-1656 caps. With 1uF input cap you created input highpass filter with slightly less bass, approximately -1dB at 100Hz and -2dB at 60Hz. Is it hearable? Ideally that cap should be of higher value to not attenuate low freqency that much. You can try to use 2x 1uF SMR in parallel.
Btw, if SMR sounds good, I'm thinking to use it also in output LC filter. 1uF value will fit nice in that place.
And Merry Christmas 🙂
Of course it is. But we want to find out and "create" the pleasing sound using right components, so we should be aware of the sound characteristics of our selected components and their combination, right? IMO that's the point of this DIY hobby.
I do understand your concern, these pps wima 1.5uf are not even on the datasheet, I believe they were part of a special order, it was discussed here:
Fake WIMA's?
But I'm 99.9% sure they are legit. I could spare a few if anyone in US would be interested.
Asuslover, sure! I’d love to just have 4 to try them out if that’s a reasonable request. I’d rather not buy the 14 on EBay and then decide they didn’t add value to my builds.
Many thanks & Merry Christmas!
Pete
Merry Christmas to you as well ppppp!
I calculated a 1uF cap creates a cutoff at 16Hz or so while a 2 would give a 8Hz cutoff (2.2 = 7.2Hz cutoff). I may try paralleling another 1uF SMR under the board as a 2.2uF Kemet SMR cap becomes too big for easy mounting.
I did order 2.2uF Mundorf MKPs to try in the pre-opamp position as well. Waiting for them to arrive..mounting them up will be a challenge 😉:deerman:
Pete
I'm curious about those Mundorfs. Personally I would love to use Mundorf Supreme as input caps, but there is a catch as 4x 10uF would be bigger than the whole Lester's board and add weight of 1kg (2.2 lbs) 😀
As to 1uF vs. 2.2uF ... Yes with 1uF and 10kOhm the cutoff is 16Hz, meaning that at 16Hz you will have half bass (-3dB). But that attenuation starting much sooner and from 100Hz down should be slightly hearable. But the more serious thing is that this C-R highpass filter also alter phase, and with 1uF you will get pretty big phase shift at audio band.
Try this calculator and compare the charts of 10kOhm + 1uF vs. 10kOhm + 10uF
RC High Pass Filter Calculator
"Try this calculator and compare the charts of 10kOhm + 1uF vs. 10kOhm + 10uF
RC High Pass Filter Calculator"
ppppp: I usually just do freehand calculation for frequency low cutoff equation to examine the absolute number..
Fc=1/(2 x pi x R (ohms) x C (farads)), but it is important to know the roll offs I agree.
Unfortunately I don’t think KEMET SMRs will come in high enough of an AC voltage rating at 1uF to fit in the "C” of the FC space that is on Lester’s boards (with 15mm lead spacing).
Cheers, Pete
Wow Pete, thanks for coming back with these findings. I am currently happy with the sound, having only experimented with the op amp NE5532, LME49720, LT1364 and LME49860. My liking is more towards LME49860 now but i intend to order OPA1656 and some other op amp to try out. i shall be experimenting with the pre opamp caps and the pre Tp3255 Caps soon for different flavours.
Correct, connection of 10K or 30K ohms from 3.3V to ground is nothing to worry about, no voltage divider since connection comes from low impedance 3.3VDC.
