HELP designing simplest crossover ever
1st order means one component only, so start with 2.2uF or 3.3uF in series with the tweeter.
You want to cross it at 6-8 KHz since minimum frequency response is 4Khz.
There are many calculators online.
I have installed Focals on my VW Golf (Rabbit in USA) but they came with a second order crossover box.
Which is what? And where are you thinking to mount the tweeter? What amp(s) are you thinking to use.
Crossovers are complicated because calculations are based on electric filter theory but speakers are NOT resistors at all. Fortunately that Focal tweeter's impedance seems fairly flat. Less fortunately, its frequency response is totally weird, unless maybe it is being measured with a capacitor and they don't say so.
Woofers in a car are generally low in the door and not on-axis at all. The woofer you propose has a pretty even power response up to 3k so yes ideally you want a tweeter that can do down nearly that low. I would be looking for a larger diameter tweeter that could cross over lower *if* you can fit that.
