Regulating high voltage (up to 450V) has become as easy as a LM317!
That is actually the comment I least expected. Removing SMD resistors is simpler than removing TH resistors but the wise thing is to design so that they don't need to be removed. Anyway, one will have a hard time finding SMD resistors that can withstand the voltages used in this circuit.
I dont know why but there is almost no info about the LR8 regulator...
Its essentially a LM317 but works up to 450V and does up to 10mA.
Pretty much enough for any 12AX7 contraption even a phase inverter.
There are three versions: TO92,TO252(DPAK),TO243AA(SOT89)
The TO92 can do the least power dissapation at only 0,74W
TO243(SOT89) does 1,6W
TO252 does up to 2,5W
I intend to add a pass transistor at the output really extending the current and dissapation capabillity of the contraption and also taking the feedback from the emitter so that the voltage is absolutely stable. I intend to replace every RC filter in every one of my old radios by this since the radios I own have quite the severe humm problem at high gains.
My other usecase will be to regulate voltages within a tube ampliffier. I have a upcoming 100W KT88 amp project in which I will be using this regulator to regulate the HV for the phase inverter and the preamp tube and also the negative bias voltage for the KT88's. Good stuff.
Try it out I sure will in two days in my radios.
And its pretty cheap aswell.
Datasheet https://www.tme.eu/Document/49ed538122efa3e11e59182b05d3cd61/lr8.pdf
This is information about the LR8 has been around for more than 15 years in this forum. Not a new news, sorry to burst your bubble.
The LR8 was mentioned as early as 2005 below and several more threads over the years.
https://www.diyaudio.com/forums/tubes-valves/68965-benchtop-ps-3.html#post783579
I don’t completely blame you though, the forum’s search parameter limits the minimum characters leading you to make a wrong conclusion.
Cheers!
1206 resistors can handle the voltage. At least from TME thats what I have seen. Yes I could make a full power supply with the rectifier, filters and so on...some radios I own have tube rectiffiers and when replacing it with a diode one for some reason the noise became much more problematic.
I might just do it for practicallity. You can use a heatsink for the transistor on that one because you can bend the transistor out. I cant make a mounting for the heatsink on the board because quite frankly not everyone feels like buying a heatsink for 3 dollars so the holes would be there with no use
The reason of the diode creating noise is obvious.
You could move the regulator to the side and have both possibilities so either a PCB mount heatsink for very low power applications or by mounting the IC to a larger heatsink or chassis. The more versatile you can design the board in a small size the more situations you can use it in. The 3 $ will only count if you buy the heatsink for that specific purpose in that specific device that has a wooden casing for instance. The added PCB footprint/pads cost nothing extra.
Cheers!
The last post is more than 10 years old so I guess the chances of anyone coming arround the topic is unlikely.
Bypassing the ADJ pin improves PSRR and reduces noise -- the tradeoff is that it results in a deterioration of transient response -- this should be a minor issue in Class A phono stage.
I guess it depends on what you mean by deterioration and what is connected to the output, particularly what types and values of decoupling capacitors. With decoupled ADJ pin, you have much more high-frequency loop gain which makes the regulator more prone to ringing, but when you manage to keep that under control, you will also have much faster settling after a load step than without ADJ decoupling.
Again I dont see a problem with it. In this case you cam mount it to anyy heatsink you wish because its on the edge of the board, Missing only mounting holes. The reason I missed them out because not everyone is happy about buying a 3 dollar heatsink when they have a huge garbage pile of them. I cant satisfy everyone to make a version of the board for every heatsink out there on the planet.
The IC tho will never require a heatsink. With the gain of the output pass element the most current that will ever be needed to be sourced by the LR8 regulator is not more than 3-4mA not even coming close to the 10mA rating and I dont think that there will be anyone dropping from 400V to 200V at 200mA...thats just not smart and it would be the only case we would hit the thermal dissapation limit of the TO92 LR8 part
Of course I mean the pass transistor when I wrote regulator. Sorry.
Correction:
You could move the pass transistor to the side and have both possibilities so either a PCB mount heatsink for very low power applications or by mounting the pass transistor to a larger heatsink or chassis. The more versatile you can design the board in a small size the more situations you can use it in. The 3 $ will only count if you buy the heatsink for that specific purpose in that specific device that has a wooden casing for instance. The added PCB footprint/pads cost nothing extra.
The footprint of many popular heatsinks is the same but it is up to you.
also talking about the heatsink thing.... How do you want to isolate the metal tab of the transistor from the heatsink.....were gonna see full rectified voltage on it and I wouldnt trust the mica insulator let alone a silicone thermal pad or a capton one. I heard about ceramic ones tho.
Correction:
PS: Look not to brag or anything, but this would be for personal use only. In my radios and stuff. It has probably 0 selling potential, so I dont have any reason to go as far as creating a real proper product, so I call it good enough. But I would go as far as making a fully done regulator. But yeah dont see a reason to actually really make this into a very proper thing. Sorry.
When I was taught a profession they taught me to do stuff right at once by stating design goals and desired results. That saves time. If the intention is not to make a proper design one is f**king around and that is OK too but often not the goal in audio. The difference between mediocre and good (or single purpose and versatile) might be 10 minutes and a few Eurocents.
In post #18 you said you would run these everywhere from now on which made me comment to make it more versatile for various scenarios 🙂
LOL, you post a simple circuit and everybody takes shots at improving it whether you ask for it or not 😀
Since we're talking versatility, shouldn't we pick a transistor with higher Vce? TIP50 is only 400V. And some of the high(er) voltage ones come with a built-in diode.
That is what fellow DIYers do when they see a design that will fail or may not perform as intended. Certainly when the person says to run the device everywhere from now on. The word "everywhere" means quite some things in my languages so it could be used in anything from a fifties mono radio to a modern tube buffer. We could also look the other way and enjoy some Schadenfreude but since we are men that do DIY audio we decided not to. It is also a cultural thing I noticed. BTW you are doing it yourself as well 🙂
Circuits can be simple but circuits can also be too simple. PCBs can be too simple too limiting the use of them for other purposes in the light of the "everywhere" statement.
