help sourcing binding post
I have an old Topward DC power supply that has some broken binding posts.
I'm looking for help sourcing a suitable replacement.
The shaft is 10-32 and approx 1-9/16" long. It need to be this long as it passes through two PCBs that are spaced 1/4" apart. 1-7/16" is the minimum length that would work.
Thanks.
I've looked but the few I've found that are long enough are metric with a larger diameter shaft. I really need 10-32 as the 1/4" spacer between the PCBs that the stud must pass through is threaded.
Wondering about just buying 10-32 threaded brass rod. I can probably live without banana compatibility.
Was hoping someone could identify the manufacturer by the knob style. I've not come across this style in my image searches.
I'd have to de-solder and remove all 8 binding posts which would be time consuming.
However, of all the speaker binding posts I've found, I'd have to enlarge the PCB pads through which the posts pass through which seems like a risky plan.
