In this video they are talking about transformers and Jim White said that transformers with low flux are better than high flux transformers. I have not tried both, has anyone tried a low flux transformer?
Transformers | Pints with Ayre - YouTube
A low flux transformer will cause lower overall hum but the regulation will be poorer they will drop more volts vs a normal one under load
I have, because I design and wind my own and experiment.
Any design is a compromise, you improve something at the cost of another factor.
It´s a good goal in OTs, because they are directly in the signal path, and lowering distortion is a good thing.
On a PT?
Not necessarily and I doubt you can "hear" it.
On a PT?
I can double that it is always a compromise, so I think there isn't 'a better' transformer. It can be better for some circumstances and may seriously depend on subjective intention of a designer.
One day I may want a low flux transformer, but the other day in other design I may want a high flux transformer, for example, to get maximum possible output power.
So do you use flux capacitors in the power supply? Sorry.
G²
Maybe also flux compensators 😀?
Hoping that JMFahey won't disagree, a PT should be designed in a way that the core just doesn't saturate neither when idling (enough turns per volt) nor with full load (enough iron) at the maximum allowed mains voltage. This yields to a transformer with stiff output voltages.
Arc welders or charging stations demand for something other, I know…
Best regards!
Best regards!
High flux, low flux transformers is BS to me.
I only know right flux and rating.
Same for O, R, C claimed to be THE best.
Whatever technology, toroids, EI and more;
There is only, the right flux for the core material with various quality and cost in steel and manufacturing.
Of course there is an ideal flux transformer, in a idealized PC simulation where outlet voltage doesnt vary and where there isnt any DC present, when designing transformers you cant cut corners and expect "One size fits all" also the meaning of "low flux" is anything but an overall idea, there is nothing to "BS" here. 😀
I am not talking about simulation, neither ideal whatever.
I am talking about actual power transformer technology.
Have you designed, calculated power transformers ?
And what is the "right" flux for you? 😕High flux, low flux transformers is BS to me.
Not such a thing, design *is* a compromise, you pick the workpoint depending on your goals, which may vary *a lot*.
You bet.
Designed, built, made, sold and delivered some 20.000 by now, for own use and for third parties.
Most PT for SS and Tube musical instrument amps, which are *routinely* abused as part of their normal life, a few hundred OTs, for Tube amps and a few for SS ones too.
All very robust, not a dozen burnt ones in that full production, do the Math.
Using Class F and Class H "electric motor" rated (150/180C at high rotational force and high G ) , high insulation and thick wire for effective current all help achieve that.
OTs very robust too: high layer to layer and winding to winding Mylar insulation and impregnation with good high dielectric varnish all help them stand full power drive with disconnected speakers, worst combination possible.
Argentine Marshall representative "Import Music" routinely replaces original British made Drake or Dagnall transformers with my own when some problematic customer is careless and burns them twice in a row.
And then they never come back.
For Power Transformers the right flux is based on the power VA rating, depending on core material with tables considering safety ratings and local practices. Then calculations follow to define core sections and windings diameters and turns, the underlying rule being equal loss between copper and iron.And what is the "right" flux for you?
It is a balance between cost and losses. When cost is the ONLY object, you jam the iron with flux until it runs hot, and damm the waste heat. (This may include "safety ratings" but they are not so restrictive.) "Low flux" is inevitably high iron cost, but it may throw less crap around and that may reduce cooling or audio shielding costs.
It may be stupid to complicate things unnecessarily. By the way, what does "flux" refer to?
But "A power tranformer" still is a quite wide area of different applications.For Power Transformers the right flux is based on ....
BTW, high or low flux is a misnomer: a 1MVA xformer might have 700,000 times the flux of 1VA one, but it will operate at a lower induction (B) which is what matters for losses, magnetic leaks, etc
This touches upon the essence of the subject matter. I am impressed.
Well.
The unit of magnetic induction is Tesla.
While the unit of magnetic flux is Weber.
Weber is Tesla.square meter. Induction B through some area S ( Flux is B.S ROFL )
machambin, I don't get that. Does it read Tesla times square meter and B times S?
Yes, it's B, the induction, that really counts in transformer design. Not to be confused with inductance, btw. It's unit is Tesla and formerly was Gauss. 1 T = 10 kG.
Best regards!
Best regards!
In saturation, a transformer core act as a source of current generating harmonics, some of which will flow directly toward the primary and secondary windings.
Conversion
Weber Wb
Tesla T
1 Wb = 1 T m²
Read: Tesla times square meter.
We do have Flux is B.S
Flux in Weber, B in Tesla, S in square meter.
Regards.
Weber Wb
Tesla T
1 Wb = 1 T m²
Regards.
- Power Supplies
- Low Flux transformers
