Hello everybody .
can you tell me where to find information on the volume control configuration made in relay similar to R2R configuration?
I also need a schematic to understand how it works.
bye thank you
bye thank you
You can have a look here: schematic.pdf * master * Jurgen Herrmann / VolCtrlDR * GitLab
The project is basically A BPPBP (preamp by Bruno Putzeys) with relay volume control (0 to -63dB).
The whole repository including Kicad files is here: Projects * Jurgen Herrmann / VolCtrlDR * GitLab
why are there different versions?
this for example:
Logarithmic resistor ladder - Wikipedia
is different from this:
The δ1 relay-based R-2R stereo attenuator
(look at menu resistor calculator)
and also from this:
Logarithmic Attenuator Calculator
this for example:
and also from this:
why are there different versions?...
What is different? I put two of your "different" examples in one image and they seem identical to me. Can you mark-up where you see differences?
I'm sure there ARE different ways to do it, but true creativity in audio is rare.
Khozmo makes relay based attenuators using different approaches. Go to their website and click on the Shunt/Ladder/Series headers to see an explanation of each type.
High Quality Audio & Industrial Attenuators and Passive Preamplifiers
in the diagram above there is a fixed resistor at the input
in the one below, however, no.
- Analog Line Level
- relay volume control
